help decoding my vin?
  • Dr. Anthony
    • Aug 2016
    • 40
    Hey guys, i've been lurking around for a while but recently registered a new account.
    I recently purchased another e30. its a 1984 325e coupe. I did the typical vindecoder, but i was a bit more curious on the numbers.
    it ends in the last 7 digits are: 1000043
    would it be safe to assume this was the 43rd e30 made in 1984?
    Production. date is 1983-12-01
    1991 318is
    F31 328d
    e70 x5d - DPF, DEF, SCR delete.
    135i cab
    F80 M3
    • 34844
    The serial numbers are sequential I think but it doesn't start over every year.
    It does sound like you have a very early build E30 though!
    • jhaurimn
      • Nov 2012
      • 2224
      When I type your last 7 of your vin into realoem, it shows 4 build months before yours. So it might not be the 43rd car built, but its absolutely a very early car
      Current:
      1989 325i
      1988 M3
      1987 325ic
      Past:
      2001 330ci
      2001 M3
      • Dr. Anthony
        • Aug 2016
        • 40
        Thanks for the info so far guys,
        I'm very curious as to the actual production number.. If I check vin # 1000001, its also a 325e with a build date of 1983-10-18 .
        Hopefully I can find the actual number.
        1991 318is
        F31 328d
        135i cab
        F80 M3
        • Dr. Anthony
          • Aug 2016
          • 40
          going to bump this up just to see..
          Is there anyway to see the production number for these cars? I'm looking to restore it.. so depending on the value of the car (ie: if its the 84th car made) I'll either restore to stock specs.. or if the production number really doesn't make a difference I'll do a nicer motor swap.. bumper conversion etc.
          1991 318is
          F31 328d
          135i cab
          F80 M3
          • AndrewBird
            The Mad Scientist
            • 11898
            Go to bimmer.work and plug it in there.
            Looks like it was made December 1st 1983.
