6.5x15 et34 = 7x15 et40 ?
  • fporro
    • 1860
    uhm,
    used this image to visualise it ...
    basically, increased inner lip by 0.5 inch = 12mm
    that draged centerline 6mm torwards inner edge, hence increasing distance from original offset location.
    outer lips are same size so hub/rim contact area did not move.
    is that so ?
    ned to make sure as the RS's will go on Zinno today.
    thanks.
  • redbull 325is
    • 7471
    sounds correct
    good luck
    pix plz
    ju
    Build Threads:
    • Dave
      E30 RAT
      • 11675
      You are thinking backwards, Frank.
      Current Cars
      2014 M235i
      2009 R56 Cooper S
      1998 M3
      1997 M3
      • Mystikal
        Wheel Fitment Expert
        • 9602
        The wheel would be ET46 now, no? The hub face is not moving relative to the car, but you just made the inside 1/2" wider.
        That wheel shouldn't even bolt up to an E30 anymore.
        • fporro
          • 1860
          yeap, deffently thinking backwards there :) hehehehe.
          et46 ? OUCH !!!
          original offset et34.0 + added 1/2" inner lip 12.7mm = 46.7
          BUT, my (midnight oil) thinking is that the Imaginary Centerline recenters it self,
          so it would be 6mm to each side, so it decreases 46.7 to 40.7 ?
          yes, the actual rim it's 1/2" = 12.35mm closer to the struts, so i don't know anymore.
          Ooh, ouch, my brain ... it hurts !!!, ttt...think...keekee...king, hoorts ma' brah-in !
          Ran this rims as 6.5 et34 on 195/50/15's and there was no rubbing.
          perhaps I'll add some spacers for now., just could not pass up the good inner lips
          on the RF's since those rims are 114.3 and had no use for them.
          the RS lips been to who knows where and back. ;)
