Hit huge bump in road
  • rturbo 930
    • Dec 2005
    • 2625
    #46
    I was expecting it to be more than that to be honest. +1 on what corbin said about picking a shop.
    • Th3importedguy
      • Mar 2014
      • 190
      #47
      He also mentioned that he doesn't have the machine to do the job 100% correct, it's sone tower measurer or something, it entailed removing the subframe hoisting the engine and some other stuff like that but honestly I don't know if it's worth it! I should probably get another rust free shell right
      E30 is life :finger:
      • rturbo 930
        • Dec 2005
        • 2625
        #48
        Originally posted by Th3importedguy
        He also mentioned that he doesn't have the machine to do the job 100% correctly.
        If he can't do the job right, go to another shop.
        I see you're in MD. I wouldn't expect getting a truly rust free shell to be that easy. Not even a CA car is guaranteed to be rust free. Get another quote from a different shop that can do the job properly and see what it comes to.
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5591
          #49
          Go to a bunch of shops, get all your quotes and compare what they say they're going to do to fix it. Should help you weed out the shit ones.
          Also, if you go that route and they ask you if you've taken it somewhere else for a quote, say no. lol
          • flyboyx
            • 8371
            #50
            or...say yes that you have taken it to a few other places but refuse to tell them what the other quotes are.
            Gigitty Gigitty!!!!
            • MrBurgundy
              R3V Degenerate
              • Mar 2012
              • 5591
              #51
              I think its so awkward when they ask you how much your other quotes and you respond with a, "Nope" :rofl:
              • BUDNUNTA
                • Apr 2005
                • 996
                #52
                ACS-md.com
                We're out there in here.
                • ahlem
                  • 369
                  #53
                  You might want to take a heat gun to some of that seam sealer to see how much more torn up things are underneath. Have a hose or fire extinguisher handy. I'm guessing it will look like someone took a can opener to the strut tower area. Take the fender off. If you are feeling brave, find a really immovable object sunk into the ground that you can attach a chain to and then jack the car up to pull the torn metal back into alignment farmer mechanic style. There a couple project blogs around where people drilled out spot welds and replaced these parts. I'd caution you not to drive the car because at some moment, you will be sitting on the road when the rest of the metal rips away.
