Help me be a better drag racer...
  • Jonathan M3
    • 1837
    Heres an old video of a drag pass in my M3 showing pretty much how to launch a low-torque peaky engined e30 on a decently prepped track:
    On this pass, I revved it up to 6k rpm and then smoothly let the clutch out, similar to how you would taking off from a normal stop. The result is slight wheelspin while keeping the revs high enough so as not to bog the motor down.
    Time from this pass:
    1.9 60ft
    14.00@96mph
    If you're on street tires like I was, only do a burnout if you have to drive through the waterbox and get water or other debris on the tires. Otherwise you're just wasting rubber.
    '05 E46 M3 Imolarot/Cinnamon - CURRENT
    '98 E36 M3 Estorilblau/Dove - SOLD
    '90 E30 M3 Brilliantrot/Black - SOLD
    SRS BSNS Motorsports - 24hrs of LeMons Racer
    • MikeE30325i
      • 2356
      my buddy bogs down in his 85 325e when he tries to burnout, it is hilarious. sounds like the car is taking a dump.
      • CleanAzzE30z
        • Jan 2004
        • 11794
        good luck to your drivetrain and suspension components while youre at it. ;)
        Mariano
        • AndrewBird
          The Mad Scientist
          • 11898
          Mariano
          Can you say "Shredded Guibo"?
          • Fidhle007
            I can fly, motherfucker
            • Oct 2005
            • 7209
            I think my mechanic will love the idea of me drag racing. He's been yelling at me to get on the track anyway and this will probably be even better for him!
            My suspension seems to be doing fine so far, we just went through it all in the last few weeks and put in a lot of solid bushings... I didn't need those fillings anyway, did I? :D
            '89 325is S50 Track Montser
            '04 X5 Daily/Tow Vehicle
            http://www.avarestoration.com
            http://www.myspace.com/brendanfiddle
            Click here if you want to be my zombie slave...
            http://www.youtube.com/user/Fidhle007
            • Digitalwave
              is a poseur
              • 6299
              A little tiny wheel slip at the start isn't a bad thing but you don't want to be burning out at the starting line. A nice 3,000 RPM launch usually works well for me.
              My automatic and 22lb wheel toting E30 did 16.3, you can do better than that :)
              RISING EDGE
              • Jonathan M3
                • 1837
                Whoops, thought you had an m42 judging by your time, sorry. ;)
                Forget what I said about the 6k rpm launch.
                • 84_318i
                  • 9
                  -28-30psi rear tires
                  -3000-3500 rpms easing the clutch
                  -just a few revolutions of the wheels to spin off dirt/debris (try to avoid goin through the water as your front tires are still wet and make a water trail... not good for traction)
                  -optional: take your backseats/spare wheel out before, thats about 70+ pounds.
                  • AdironRider
                    • Dec 2004
                    • 3491
                    Lauch between 3000-3500. My 200k 325is ran a 15.6 after some trial and error in that range.
                    Back to my roots
                    • Fidhle007
                      • Oct 2005
                      • 7209
                      Thanks guys, I figure I should be in the mid 15s with a proper launch. I was trying to spin the wheels and they were just hopping around on my like kangaroos on meth.
                      I've been practicing a bit and I think I'll be able to do much better next time. I'm going back again this wednesday (the 20th) if anyone would car to join me!
