What was the FIRST thing you bought for your E30?
  • PacificExposure
    • Mar 2018
    • 152
    I was laughing with my brother because his new-to-him '73 2002 is on a truck being shipped cross-country and he's already deep in parts and falling down the rabbit hole. What was the first thing you ordered/picked/scavenged for your E30?
    I replaced all the things I touch first: the aging shift knob and brake lever with UUC machined pieces and steering wheel with a 350mm Viilante tri-color steering wheel. Still my favorite things about the car.
  • Aleman
    • Mar 2012
    • 1611
    My first order was for this stuff:
    Head Gasket Set
    Shift Knob
    Bottom End Gasket Set
    Oil Filter
    Air Filter
    Exhaust Manifold Nuts (copper)
    Cylinder Head Bolt Set
    Spark Plugs
    Therm Gasket
    Therm O-Ring
    Thermostat
    Bumper Rivets
    Fuel Filter
    A nasty shift knob should be replaced right away.
    R135 /// 1990 Alpinweiß II 325is
    └┼┼┘ /// 1993 Black/Black Convertible (sold)
    ..24
    • rube207
      • Jan 2018
      • 7
      A new z3 shifter to replace the horribly worn out e36 shifter that was in it. Didn’t shorten the throw much more, but getting rid of the slop was well worth the price.
      • djkostas
        • Jan 2016
        • 8
        Hm...
        First was a USB stereo unit to replace the cassette player.
        Second was a Z3 4.27 torsen diff.
        After that I just lost track.
        • LowR3V'in
          • 4209
          probably m3 springs/rear sway and cabrio front sway bar.
          perfect combo btw but then get ie3/koniSA/bimmerworld rear shock mounts.
          that was like 10-13 years ago.
          • SkiFree
            • Jun 2011
            • 2766
            Nardi Classic steering wheel for my 2002. Wanted one for ages.
            Welcome back to Instagram. Sign in to check out what your friends, family & interests have been capturing & sharing around the world.
            ADAMS Autosport
            • MrBurgundy
              R3V Degenerate
              • Mar 2012
              • 5616
              springs/shocks
              I ain't about that stock ride height, yo.
              • wolfador
                • Mar 2018
                • 33
                Timing belt, water pump, thermostat, coolant hose kit and V belts. Parts arrived before the car did from the shipper lol.
                86 325e sedan
                • Magnaflow Cat-back
                • SSSquid Stage 1 Chip
                • Vincent Brick
                  • Feb 2013
                  • 879
                  According to my records, it was...
                  Oil/filter, new crank position sensor, oxygen sensor (Bosch)... hood prop strut, trunk roundel (OEM BMW), used turn signal switch.
                  1991 325i Sport - Calypsorot Metallic - DAILY DRIVEN
                  WTB in SoCal: 8"/10" Lukebox, leather Sport steering wheel, 60L MotoMeter fuel gauge, Thule/Yakima roof rack
                  • 88BlackS-ETA
                    • Mar 2013
                    • 322
                    Before I even bought a E30, I got a center console, front door panels and rear panels.
                    When I got the car I had to replace a headlight lens to pass inspection after that the REAL first thing I bought was a timing belt, tensioner, water pump and some gasket that was leaking.
                    Feedback Thread
                    • Reichart12
                      • Aug 2012
                      • 2168
                      springs/shocks
                      For my current e30, this is the same for me... Although I did get a rear plate filler technically first as it was a Christmas gift.
                      Instagram: Reichart12
                      • Stanley Rockafella
                        • Aug 2011
                        • 4062
                        All tune-up related stuff: filters, timing belt & tensioner, tires, etc.
                        • Miguel801
                          • Oct 2016
                          • 9
                          hmm
                          Hella headlights.
                          • Das Delfin
                            • Sep 2014
                            • 2293
                            Fuses to make the headlights work ;) and some replacement bulbs for the side marker lights
                            • wworm
                              • Dec 2016
                              • 1719
                              New drivers seat and a working head unit. Old one had a french quartet cd stuck in it and would play constantly on very low volume. Goofy first ride home
                              1984 Delphin 318i 2 door
