What to buy to knock out the coating on aluminum wheels to begin polish?
  • O 16581 72452 5
    • 1066
    I snatched up some Porsche Powerslots, two look like a mirror and the other two are dull (like silver paint), tried some aircraft remover because i thought maybe it was clear coat or something, no dice. I began sanding at it and it's taking forever and making deep scratches i'm having a hell of a time getting out, looking the most ideal thing to use for a hand drill to get it knocked down.
  • 2002maniac
    • 4260
    oven cleaner + scotchbrite. Wear gloves.
    • O 16581 72452 5
      • 1066
      Thanks! I'll try it out later tonight. Hopefully i can revive these deep ass scratches. :|
      • mrsleeve
        • Mar 2005
        • 16390
        might be powder coated??????
        Originally posted by Fusion
        William Pitt-
        • O 16581 72452 5
          • 1066
          Possibly, sucks though.
          • O 16581 72452 5
            • 1066
            Oven cleaner failed, i'm going to bead blast it at a friend's in a few days.
            • StereoInstaller1
              GAS
              • 22679
              You might wanna try Acetone. Got the clear coat off of my IROC wheels, but I would media blast if I were to ever do it again. What a PITA!
              Luke
              Closing SOON!
              Thanks for 10 years of fun!
              • der affe
                Technical
                • Dec 2005
                • 8452
                alum aircraft paint stripper....work almost every time and it is cool to watch it work. WEAR GLOVES!!!!!!
                60% of the time it works every time
                • O 16581 72452 5
                  • 1066
                  I'm going to try bead blasting.
                  • der affe
                    Technical
                    • Dec 2005
                    • 8452
                    PLASTIC MEDIA OR WALNUT SHELL BLAST THEM! sand will really rough up the surface and cause you more work in the end and destroy any details such as edges of spokes etc. i used to do alot of alum polishing and stripper took off just about everything except for power coat or anodising (sp) ie early porsche alloys. the factory porsche wheels are painted if they are not forged/chromed/ or have been powdercoated by some one after the fact.
                    • O 16581 72452 5
                      • 1066
                      What i have is like black beads, i'm not sure what it is, is that plastic media?
                      • dirty30
                        • 3124
                        Fantana.
                        I'm going to be honest with you, that smells like pure gasoline.
                        • der affe
                          Technical
                          • Dec 2005
                          • 8452
                          it may be. where did you buy it? usually you have to go to an abrasives supplier to get the walnut or plastic medias. sand is usually had at the depot or lowes etc. it could also be lead or steel shot both very bad ideas to use!! what does the outside of the container say?
                          • O 16581 72452 5
                            • 1066
                            I just got it from a depot type store (Menards), it's probably the lead/steel shit.
                            I need to figure out something, i want to get these things on. :|
                            • joshh
                              • Aug 2004
                              • 6195
                              Media blast (as Der affe said) is your best bet. I stripped mine down pretty well a good strong stripper then had them media blasted.
                              "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
                              ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
