driving a wreck
  • rede30
    • 4697
    driving a wreck
    I will probably be buying a 90 325i with a front end collision. It drives but the engine fan hits the radiator. The fan spins and the car was driven about 30 miles after the accident but i want to drive the car 8 hours from norcal to socal. Do you guys think it would be ok to take the engine fan off and drive during a cool night, with no aux fan either. The hood is permanently popped because of the wreck so it seems like as long as there is movement it should be fine with air flow. Should i just let the fan spin against the radiator? Or should i just trailer the bitch. I think my dads truck can pull a car, i was just trying to save gas money. Do i just need to disconect the drive shaft from the diff for putting the car on a dolly?
  • Jand3rson
    • 37587
    You're going to want to have at least one fan. Is there no way you can get the aux fan to work?
    If that's not an option, I would just tow it.
    • equate975
      • Jun 2004
      • 3382
      Depends on what your definition of a cool night is. Even on a hot summer day (90+) I drove my 325i without a fan (well it was stuck to the shroud) As long as I kept going it was cool, but in the taco bell drive through I hit the red, then realised my fan was stuck.
      Rollin' with a Geistkuchen
      • golde30
        • 11464
        i say as we go into winter, you would be cool leaving at like 6pm, maybe wire up the aux fan to the battery.
        IG: @Baye30
          • 34844
          if you are moving you should have no trouble. it takes my car 10 minutes of idling to reach the temp cutof for the aux fan to kick in (1/2 mark with the E36 M42 switch, no clutch fan) and it never comes on when I'm driving. on the freeway it always stays in the normal temp range (between 1/4 and 1/2), and at high speeds it actually drops to 1/4. the clutch fan is pretty worthless imo..
          • ivo316
            • Oct 2006
            • 1222
            Try pulling the metal a bit, maybe you can get it to rotate, if not keep a close eye on the temp.
            Good luck
              • 37833
              BS dude, during highway driving you do not need a fan at all.
              My turbo car had only 1 electric fan and I left it off on the freeway.
              Grover Beach, California
              BimmerHeads.com
              • rede30
                • 4697
                I would be driving up the grape vine on the I5 so thats a little scary. I am thinking driving it may be plausible. Thanks for your imputs, keep them coming.
                • Jand3rson
                  • 37587
                  I guess, but on a car that has been wrecked in the front, and had the fan hitting the radiator, I'd be wary of what other damage the cooling system may have sustained. I would want a fan.
                  • 2002maniac
                    • 4260
                    My car has no clutch fan and the electric fan never comes on when I'm moving over 40mph
                    You will be fine.
                      • 37833
                      Well I would expect he'd give it a once over before driving for hours.
                      BimmerHeads.com
                      • mattdk318i
                        • Jun 2006
                        • 3953
                        The fan cluth in my 318 has been broken since day one. Its been 3 years and its yet to overheat.
                        The aux doesnt work either.
                        You will be fine as long as you keep an eye on fluid levels
