So I got the 95 M3 rack... I think
  • JGood
    • Jan 2004
    • 7959
    So I order a 95 M3 rack about 4 months ago. After out of stock parts, incorrect parts, delays, mishaps, clusterfucks, etc... I finally received a "95 M3 steering rack". It looks like one, smells like one, and tastes like one.
    Why does it only turn 2.5 times lock to lock? Z3 is 2.7, 95 M3 is 3.0, 96-99 M3 is 3.2
    Bob from Eurasian assured me he finally located a 95 M3 rack and had the company he ordered it from absolutely positively verify that this is a 95 M3 rack from a 95 M3.
    I guess I'll compare the overall movement with a stock rack and insure it's actually moving the same distance. If so, and this rack does indeed have the same mounting dimensions as a e36 rack, what the hell is it from?
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    You're right, a '95 M3 rack should have 3.0 turns L2L. 2.5 is really, REALLY short. Are you sure?
    I put a '95 M3 rack in my car. It feels great, can't get enough of it and it was indeed 3.0 turns L2L.
    Check the serial number it came from and match it with what car it came off of. I got my M3 rack from Eurasian as well and it was perfect. I hope you don't have a jam or something inside the rack...
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • FredK
      • 14752
      Maybe it has a steering angle limiter built in? This is a common upgrade to prevent the wheels from rubbing the inner fender liners. I'm not sure it would limit travel that severely though. You can check by pulling the rack boots back and looking at each end of the steering shaft.
      • JGood
        • Jan 2004
        • 7959
        That got me thinking. The lines were capped, and fluid remaining in the rack could have "locked" it shorter because there is nowhere for the fluid to go. But it felt like a mechanical stop, it was fairly abrubt as I was turning it. I will mess with it more tonight, I was way too tired last night.
        I doubt I'll be able to get the serial number for the car. I don't even know where Eurasian got the rack from.
        I guess it could have a limiter, I'll pull the boots off as a last resort option. They still have nice clamps on that I was gonna leave on haha. I originally paid for this rack months ago when I had money. Now I'm so broke it's not even funny. I don't even know if I can afford the spacers to install it haha.
        Thanks
        • PiercedE30
          • Apr 2005
          • 4220
          it should have a grey color to the metal. i know there is a way of visually telling but i don't know what the different colors are.
          My 2.9L Build!
          • Fidhle007
            I can fly, motherfucker
            • Oct 2005
            • 7209
            Good luck with the rack, I look forward to hearing how it turns out!
            I'd love to do this upgrade but everywhere I look it says "For cars with an airbag you'll need to do some fabrication at the firewall." Fabrication of WHAT???
            '89 325is S50 Track Montser
            '04 X5 Daily/Tow Vehicle
            http://www.avarestoration.com
            http://www.myspace.com/brendanfiddle
            Click here if you want to be my zombie slave...
            http://www.youtube.com/user/Fidhle007
            • FredK
              • 14752
              Some filing, maybe.
              • Brew
                • 3060
                Yeah, you need to clearance the firewall about 1/4" so that the steering shaft doesn't hit. Other than that, it bolts in. P/S hoses depend on which engine you have.
                '91 318is
                • Fidhle007
                  • Oct 2005
                  • 7209
                  M20B25, stock for now...
                  • Garageaholic
                    • Dec 2005
                    • 5204
                    they have many a writeup about e36 racks into an e30 w/ airbags and what firewall mod is necessary
                    Recent Rebranding!!
                    E30 SM62/S62
                    E30 M60 V8
                    E30 M30 Big 6!
                    • JGood
                      • Jan 2004
                      • 7959
                      It's a 3.0 turn lock to lock rack, the boot was hanging up on the tie rod and not allowing it to go the whole way to one side. It's been sitting for a while...
                      I cleaned it up and it looks like new. Can't wait to get it installed.
                      • PiercedE30
                        • Apr 2005
                        • 4220
                        good deal........and remember to take lots of pictures for us to see the mess you make with it.
                        My 2.9L Build!
                        • JGood
                          • Jan 2004
                          • 7959
                          Won't be a mess. My current rack is capped, no P/S. This rack will be the same. Filled with Redline ATF and capped off. Actually, it won't be capped, I run a hose between the connections so there's no pressure when the wheel is turned the whole way.
                          The e36 tie rods are so beefy compared to e30 rods! Not that it really matters...
