its a dart
Natural Causes? Or Foul Play?
you were out drifting weren't you ? j/kMtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
At the garage I used to work out, someone left a 3/8", 3" long extension on the floor, and apparantly it was standing straight up.
It ended up straight through the tread of an 18" Chrylser 300C tire. That's 3/8" wide, and it just slipped right into the tire.
I think you probably hit a branch, and it got caught up in your axle/suspension and got forced into your tire. If a 3/8" extension went through the entire tread block, a stick can go through the sidewall.Comment
Not to sound like a CSI detective but... I am looking at this picture and I see marks on the sidewall consistent with someone running up against the edge of a curb so at first I concluded that a branch could have been up against a curb.. but then when I look closer and see a rectangularish looking mark around the entry point of the stick, it looks almost as if someone held a sharp instrument (like a nail) against the sidewall while hammering the hole and then went back and hammered the stick in its place.Comment
That was from rubbing, my rear struts were non-existent no fluid was left in them. They finally gave out when I had a load of 5 guys in my car.Not to sound like a CSI detective but... I am looking at this picture and I see marks on the sidewall consistent with someone running up against the edge of a curb so at first I concluded that a branch could have been up against a curb.. but then when I look closer and see a rectangularish looking mark around the entry point of the stick, it looks almost as if someone held a sharp instrument (like a nail) against the sidewall while hammering the hole and then went back and hammered the stick in its place.
I replaced them a week or so ago.
Also, I found it was a nail! I thought it was a little frozen branch, but after letting it thaw out in the garage I noticed a point on the end and it was a nail. Never the less though, somehow the head of the nail went in, not the pointy end. Probably natural causes I guess, still weird that it ended up in my sidewall though.Rollin' with a GeistkuchenComment
