Does anyone have any pics of an e30 with a roll cage in it??
  • 89325iturbo
    • Mar 2004
    • 723
    I've seen some on a message board just can't remember which one.
  • Low Level E30
    • 1646
    I have an E30 with a cage in it - nothing spectacular though, just a 6pt bolt-in Autopower. What d'you want to see?
    There are plenty of -real- cages out there in E30s - check the SpecE30 YahooGroup.
    • 89325iturbo
      • Mar 2004
      • 723
      My brother might be renting a pipe bender, so when he had it i was thinking about make a cage. Nothing crazy, probably something the same as you have a 6 point.
      • Low Level E30
        • 1646
        Mine goes into the rear wheelwells, down to the floor at the B-pillars, and into the floor where the dead pedal would be on the driver's side, and opposite side for the passenger.
        It has door bars, a cross beam for the harnesses, and a support for the driver's seat.
        Nothing spectacular.
        You can check it out online at www.ioportracing.com - I don't have pics currently, or I'd send 'em to you.
        • jht3
          • 288
          pipe bender or tube bender. there is a difference. if you try bending DOM tubing w/ a pipe bender you will end up kinking the tube. i recommend a JD2 tube bender for a serious cage. pipe is for water.
          James
          '88 M3
