Are fuel pumps for 318is and 325i the same???
  • psloan
    • 9815
    I need one for my 2002 and i only know that the one from a 325i works. I cant cross reference the pns on real oem for some reason - it doesnt show on the 6 cyl. Thanks
  • FredK
    • 14761
    no
    • psloan
      • 9815
      Originally posted by FredK
      no
      Yeah - bavauto pns are different.
      • M42Technik
        • 9781
        Yes the 318iS one is specific to its model. Costs a little more too, sadly. Enjoy replacing it, its a little frustrating. Here is a very good DIY page for the 318iS fuel pump:
        Also check out the rest of this site, very informative if you have the 318iS. Enjoy!
        Reminiscing...
        • FredK
          • 14761
          The M42 318i and 318is use a single in tank pump made by VDO. It looks different than the pumps found in the 325 family.
          • winstontj
            • Mar 2007
            • 500
            pat you need one from a 1991 m42 318is ONLY. This is the same depth as our tanks (so the gauge reads correctly) and they have the built in high pressure fuel pump, sender & all that all in one drop in unit.
            All others (like the e30 m10 one I mentioned to you) you'll need the seperate tripple cluster (clusterF) under the chasis with accumulator, filter & high pressure pump. All others are sender & low press units OR low & high press units but no sender (325m20).
            that's all what I believe to be true - but it could be wrong. I do know that you want a 1991 m42 318is in tank pump from an e30 car.
            • psloan
              • 9815
              Thanks TJ. I'll pick up the one here locally as it is new.
                • 34839
                it's different because the tank is smaller
                • jflip2002
                  • Sep 2006
                  • 4377
                  I s how the same part number on an 84 318i and an 86 325i. Carter # P72018, and Im at work right now =\
                  Originally posted by blunt
