My s50
  • Jonathan M3
    • 1837
    How much did the s50 run you, if you don't mind saying???
    '05 E46 M3 Imolarot/Cinnamon - CURRENT
    '98 E36 M3 Estorilblau/Dove - SOLD
    '90 E30 M3 Brilliantrot/Black - SOLD
    SRS BSNS Motorsports - 24hrs of LeMons Racer
    • lukasbmw
      • 651
      Sorry to hijack but...
      Green = 17lb
      Pink = 21lb
      blue = 24lb
      Am I correct on this?
      I'd assume that since 95 M3's came with 17lb injectors, I won't have to upgrade mine unless I am putting more then 220hp to the wheels with my modded m50 engine.
      2004 SL600 - Current
      2006 SL55 AMG - Sold
      2004 M3 SMG - Sold
      1999 540i Sport - Sold :(
      1989 325i coupe- Sold
      1988 325is M50 M-tec - Sold :(
      • Bryson
        • 1490
        heh, i just put that identical motor into an e30 over the weekend. The s50 comes with green top 17lb injectors
        you should like it :)
        edit: I used a getrag 260 with many miles on it ;)
        • Beau B
          • Mar 2004
          • 734
          ///Mtechnik88 - I am in Dublin right off of Sawmill - pm me
          I am hoping to have the motor ready for install by the end of this month and installed by the beginning of June, I was hoping to have it done sooner, but I don't think I will be to complete it by than
          1988 BMW 325iS
          • Beau B
            • Mar 2004
            • 734
            Jonathan 90 M3 - I got the engine, tranny, all the shfit linkage, shift boot, shifter, front struts with hubs, calipers, rotors, and springs, flywheel, pressure plate, control arms, driveshaft, and rear springs for $3700 shipped to an airport near me. I think I got a pretty good deal, since alot of that stuff I am going to try and sell.
            Beau
            1988 BMW 325iS
            • Mtriple
              • 3139
              Congrats on the motor!!! I am just finishing up my S50 in my 89 325i, should be done in the next couple of weeks.
              -95 S50 and tranny with 60k
              -VAC Stage 1 head with motorsport springs(dual) and hardened retainers
              -VAC timing/cam/oil pump chains
              -VAC oil filter relocation
              -Schrick cams
              -24lb injectors
              -Turner/Conforti software
              -UUC 8.5 lb flywheel with E34 M5 clutch
              yada, yada...
              Originally posted by Simon S
              • Beau B
                • Mar 2004
                • 734
                Mtriple - looks good I hope to be where you are in the next few months. How does the UUC flywheel look that is the one I was thinking about going with. Do you have anymore pictures of your engine it is beautiful.
                Beau
                1988 BMW 325iS
                • Mtriple
                  • 3139
                  Beau
                  Thanks Beau, The UUC flywheel is really nice. I've beem running it in my M3 for almost a year now. A little bit of chatter in neutral, but its minimal. Pedal feel is a bit softer than the stock M3 setup, which I like, and it is more than capable of higher HP with the E34 M5 clutch. My M3 is making 321rwhp and there isnt even a hint of slippage.
                  • Charlie
                    kid tested, administrator approved
                    • 6686
                    Originally posted by ///Mtechnik88
                    Hey Beau, what part of Columbus are you located? If it's not an issue I'd enjoy shadowing some of the process of the install, as I'm looking to do the same next year.
                    Allow me to second this, If you need a seperate set of hands.
                    Btw Beau, I talked to the guy possibly buying your M20 last weekend at Mid Oh.
                    -Charlie
                    Swing wild, brake later, don't apologize.
                    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                    FYYFF
                    • Beau B
                      • Mar 2004
                      • 734
                      Charlie - Thanks for the offer, I will definately let you know when I am ready for the swap. Thanks for the offer, oh who did you talk to about my M20? There were 2 guys that asked me about it.
                      Beau
                      1988 BMW 325iS
                      • grk325
                        • 178
                        one hell of a deal you got for all those parts
                        • pogiboy9
                          • 475
                          what do you plan to do with your old engine and tranny....Depending on how much you ask for i'll get it from you
                          http://www.decal-spec.com
                          • Beau B
                            • Mar 2004
                            • 734
                            Pogiboy9 - I have a few guys that are interested in it locally but no one has commited yet
                            Beau
                            1988 BMW 325iS
                            • pogiboy9
                              • 475
                              WEll just holla, depends how much you want for your ish and depends when you decide i can :)
                              • Den
                                • Mar 2004
                                • 162
                                Stu - I know that your dad actually recommended the 260 tranny . . .
                                Why is the 260 preferred?
