Shop owners and workers.
  • Maluco
    • Oct 2005
    • 6572
    Do not do it unless you have a hydraulic press or some tool you can use an air tool to remove/install it..
    • CarsSuck
      • Oct 2005
      • 968
      My brother did these on his e36. Rent a bearing puller, its the only way. Even with that, it can be tricky. He screwed up one of the new bearings during the install. Its not impossible to do correctly yourself, but it takes time, effort and a lot of patience.
      --Will
      • PiercedE30
        • Apr 2005
        • 4220
        You don't need a hydraulic press!!!
        There is a bearing puller that looks like a gear puller and some big metal disks that pull it out.
        One of the guys that I work with can do the passenger side rear wheel bearing in under an hour.
        My 2.9L Build!
        • MrK
          • Jan 2006
          • 709
          Wow I kinda feel a little bad for you guys. Labor in Leb is MUCH cheaper. I got both my rear wheel bearings replaced for cost of parts +$50 :D
          This is your M20 on steroids:
          • T.Dot_E30
            • Mar 2004
            • 286
            Originally posted by AdamF 88iS
            It's $300ish each at my shop. Thats with OEM brand bearing. The left side is slightly more difficult than the right, so don't be surprised if that one is a little more expensive than the other.
            Why is that? I've done both and dont recall the left side being harder?
            My first time doing it, the right side took me 3-4 hours to figure out.
            I did the left side on my lunch hour the next day.
            • AdamF 88iS
              • 2051
              Yea, all you need is a large threaded shaft, 2 nuts for it, and some various metal plates to do it. No need to pull the arm out and put it in a press unless that bitch is really stuck in there.
              Adam Fogg- '88 M3
              Common sense- It's the new 'gifted'
              • AdamF 88iS
                • 2051
                Exhaust is in the way on the left side.
                Adam Fogg- '88 M3
                • FredK
                  • 14759
                  OK MrK you can stop rubbing it in. Didn't you say that you can get complete S50B32s for like $2k complete as well!?
                  • MrK
                    • Jan 2006
                    • 709
                    @FredK: No I didn't say that LOL. Parts are priced similarly to the US here (including the ridiculous availability of anything eurhhho), it's just labor that's cheaper :D
                    • E30 Wagen
                      I had mine done for about $100 in labor.
                      Sorry, off topic, but what would be some symptom of a bad wheelbearing replacement job? Now I have some metal rubbing sounds about 6-8 months later. Could my mechanic have botched the job?
                      edit: I know it's not the brakes.
