Do you need a spring compresser to install the H&R Cup K
  • KrayZE30
    • Mar 2004
    • 113
    Or do you just directly swap the assemblies? The reason I'm asking this is because I have to install these in my garage instead of my usual shop, so I'm working with limited tools.
    -Sean
  • Digitalwave
    is a poseur
    • 6293
    You don't need a spring compressor to get the new spring on, but you should use one to take the old spring off. Although, last time I installed a Cup Kit on an E36 all I did was loosen the top bolt and let the spring shoot off the strut so I didn't have to a rent a compressor.
    The new spring is short enough not to need one though.
    RISING EDGE
    • Bill 84 318i
      • 1600
      I needed to compress the hell out of the springs. The shock doesn't stick out very far.
      • Digitalwave
        is a poseur
        • 6293
        Well nevermind then. I guess E36's are that much different.
        RISING EDGE
        • m42technic
          • 1056
          :shock: :loco:
          James Peacock
          WWFSMD?
          • krisco
            • 180
            :stupid:
            Besides, renting a spring compressor is free.
            • franz
              • 631
              FWIW my H&R sport springs do not compress with Bilstein Sport struts and no pads.
              • KrayZE30
                • Mar 2004
                • 113
                I'm confused. Ive never actually done any suspension work, but ive seen theinstallation of GC Coil Over onto an integras stock shocks, and you had to compress the spring to take it off the shock. But since I'm getting the H&R Cup KIt, dont the springs already come installed on the shocks? So cant I just remove the whole stock assembly and replace it with the CK? If I do need a spring compresser, wheres the best place to rent them?
                -Sean
                • aaron_silva
                  • 1785
                  No. You have to re-use your strut housings. That means you have to put the shock insert inside the housing and then put the spring on.
                  The silver part (left) is a painted strut housing. That is not included in the kit.
                  HTH.
                  Aaron
                  • Stu Mc
                    • 4083
                    HTH.
                    Aaron
                    That picture is of an E36 318/325 Cup Kit. non-M E36's use a single piece strut housing/strut tube combo. I see your point though.
                    I never waste time with spring compressors when taking the spring out. Installing new springs is a different story--if the spring is short enough, you won't need em. If it's too long, you'll need to compress them.
                    PM Rob, he put a Cup Kit on his car, so he'll know if you need compressors or not.
                    You have a shop and you've never done suspension work? Interesting.
                    • KrayZE30
                      • Mar 2004
                      • 113
                      Thanks for the replies. I think Illl just give it a try and see if it works out.
                      And yea ive never done suspension work myself, but ive seen some of the other kids in my HS auto class do them.
                      Hopefully itll work out and I can post some pictures of my new ride with kopis and the CK. :) Cant wait:) WHERES THAT DAMN FEDEX MAN??
                      -Sean
