radiator fan
  • P12od
    • Mar 2007
    • 109
    radiator fan
    my radiator fan stopped spinning ...":( any suggestions
    Firetruck?!?!?!
  • Jean
    • 18228
    I would check if there is power coming to it or resistor first.
    • Mike325
      • Mar 2006
      • 3685
      As well as checking to see if it can spin by hand. Do that test with the key off tho. Just in case it turns on.
      Originally posted by Kershaw
      • PeaveyBassist
        • Sep 2004
        • 3511
        Make sure it spins. Check fuses. Key on and A/C on should turn the fan on. If it spins by hand, no fuses blown and it turns on with the A/C button, you probably need a fan switch thats on the radiator itself. If it doesnt work with the A/C button, leave the button on and the key on. Unplug the fan and at the car side of the plug check for voltage with the key on. If you have voltage, youll need a new fan. If you dont, you have a problem somewhere else.
        Will
        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
        Welcome e30 (brilliantrot '90 325is) 12/23/06
        DaveCN = Old Man
        My signature picture was taken by ME! Not by anyone else!
        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
        • Jscotty
          • Jan 2007
          • 2285
          I addition to what has already been suggested, it would be a good idea to apply voltage directly to the fan to see if it spins. Electric motors made of plastic fail regularly.
            • 34830
            huh? the motor isn't plastic.. only the fan blade is.
            • Jscotty
              • Jan 2007
              • 2285
              Sorry.. allow me to clarify. The way that the fan encases the motor causes more stress on the motor because the plastic can warp ever so slightly. This in turn makes the motor work harder and because of it, electric motors that are driving plastic parts are more likely to fail.
                • 34830
                okay, that makes more sense :p
