Wheel studs?
  • 8atman
    • Apr 2007
    • 492
    Wheel studs?
    I have a set of after market wheels and they require after market tuner lugs and studs. I got a set of lugs with the rims but now I need some wheel studs with 12 x 1.5 to go in the hub and fit the lugs. Does anyone know of a shop online that sells what I'm talking about? They are usually about 35-45mm long and have an Allen key at one end.
    Thanks in advance.
  • browntown
    • Jun 2004
    • 3524
    vorschlag, turner
    • Mike325
      • Mar 2006
      • 3685
      Just make sure you get ones that they are the correct length for your wheel's offset.
      Originally posted by Kershaw
      • 8atman
        • Apr 2007
        • 492
        sweet thanks guys. Yeah they are for my sportmax 002's with 0 offset. I think 35-40 mm should be fine.
        • 8atman
          • Apr 2007
          • 492
          Does this look about right? http://www.ezaccessory.com/Wheel_Stu...75_p/st948.htm
          does it look to short?
            • 34839
            that only matters if you are using a spacer.
            no spacer = stock length
            spacer = longer studs
            having ET0 or 20 doesn't make any difference.
            • Rennsport
              • 2139
              or you can use merc wheel bolts, they are longer and will accomidate for a spacer.
              m106 1990 e30
              e36 daily
              e32 cruiser
              • 8atman
                • Apr 2007
                • 492
                sweet thanks guys looks like Im just going to order a set of those for now.
                Thanks
