Upgraded Axles
  • e30ryan///m3
    • Dec 2005
    • 249
    Upgraded Axles
    Hi Guys,
    Do any of you know if there is an upgrade to stock axles?
    1988 M3 (Diamondshwartz)
    2004 M3 (SilverGray)
  • bmwm3n528
    • 3654
    Originally posted by e30ryan///m3
    Hi Guys,
    Not sure, I do seem to remember Diego fabbing some of his own...
    Trevor Ely
    '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
    '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
    • e30_kid89
      • Apr 2006
      • 489
      if i remember correctly i think jordan used the beefy MZ3 halfshafts without modfication on his e30....i could be wrong.
      • Mr Deagle
        • 1121
        mz3 is larger than stock (u joints, and actual diameter)
        you can use mz3 differential output flanges, z3m axles, and z3m rear hubs, and get a 5 lug setup for the rear
        • Ray Smoodiver
          • Jun 2004
          • 8809
          With an MZ3 setup, you can use Euro M3 halfshafts, which are the same thickness, but are hollow - thus being lighter and stiffer.
          • PiercedE30
            • Apr 2005
            • 4220
            you could do the e28 shafts since they bolt to the hub of the wheel...
            My 2.9L Build!
            • e30ryan///m3
              • Dec 2005
              • 249
              I have a set of MZ3 half shafts what else would I need to install these? I also have a set of e36 rear trailing arms and hubs
              Oh and I forgot to mention that it is on an e30 m3 so it is already 5 lug
