Caliper go bye bye from carrier...
  • dude8383
    • Jan 2005
    • 10387
    #31
    Thanks guys!
    Really appreciate all of the help!!
    Yes, it does suck...but thankfully its all replaceable.
    I hope I can find another wheel...:(
    • AC Nico
      • 3619
      #32
      the problem is not the broken caliper, tire or brake disc... the problem is that rim. as i told you, i will do my best to find one.
      *** For sale: euro stuff, BBS steering wheels, smoked tail lights, bunch of rare wheels (5x120 and 4x100) ***
      [/color]
      • dude8383
        • Jan 2005
        • 10387
        #33
        Yeh...exactly man. all of that shit is replaceable!
        Let me know man.
        I saw a 15inch on ebay.de today...hopefully a 16 will pop up.
        • AC Nico
          • 3619
          #34
          there are only 16" for mercedes benz :(
          [/color]
          • golde30
            • 11464
            #35
            redrill the benz one to 4x100.
            IG: @Baye30
            • Massive Lee
              • Sep 2006
              • 6785
              #36
              Is that possible that some monkey mechanic forgot to tighten the carrier's bolts? At least, it looks very much like that. Are the two 12mm bolts still with the remains of the carrier and attached to the two mounting ears?
              Or did you do a brake job lately and forgot to tighten the two bolts to 85ft.lb?
              massivebrakes.com
              • dude8383
                • Jan 2005
                • 10387
                #37
                That is not a bad idea.
                Where can I get em re-drilled, I've never done anything like this before.
                I did the job myself, and I torqued them to spec!
                Its possible I may have missed a bolt though...
                I don't know...I just want to get it fixed so I can get her back on the road!
                • AC Nico
                  • 3619
                  #38
                  problem is that you allready have 6 holes in the MB rim - 5 for the bolts and one for the cap.
                  it will look like cheese with another 4 holes. :(
                  [/color]
                  • golde30
                    • 11464
                    #39
                    last resort though...can always run the caps so no1 will see the holes.
                    IG: @Baye30
                    • strad
                      • Jan 2007
                      • 241
                      #40
                      I had a carrier bolt come out after my last brake job. I had tightened it properly too. No damage, but the new one went in with threadlocker!
                      The current fleet:
                      1992 325ic: 148k-171k miles
                      1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
                      1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
                      • Jscotty
                        • Jan 2007
                        • 2285
                        #41
                        I don't know how possible this is but I often see situations with 2 piece wheels on monster trucks where they will remove the spider from the wheel, fabricate a new one and weld it in place.
                        The center section of your wheel isnt exactly a spider but maybe it can be cut out and a new plate can be welded in place. Then you can drill out new holes.
                        • Hartge_H27
                          • Jun 2006
                          • 1699
                          #42
                          Damn i am sorry bout this. I had the same thing happen to me. but give me the specs of ur wheels and i will call a friend in germany to see if he can find one.
                          • dude8383
                            • Jan 2005
                            • 10387
                            #43
                            Golde30:
                            How safe do you think re-drilling a rim is?
                            16x7.5 ACT Rims.
                            Let me know if you need any more info. I'll try to dig up a name or something!
                            15inch version:
                            http://cgi.ebay.de/2-ACT-Allufelgen-...QQcmdZViewItem
                            Thank you very much!
                            • Digitalwave
                              is a poseur
                              • 6293
                              #44
                              That doesn't look like a rim you could redrill to 4x100 without welding the original holes closed. I wouldn't trust it personally.
                              A similar thing happened to rwdrift, but one of his carrier bolts sheared off, causing the other one to break as well. Did the same thing to his rim, punched a hole right through it.
                              RISING EDGE
                              • Hartge_H27
                                • Jun 2006
                                • 1699
                                #45
                                what is the et #
