FYI - Aluminum e36 Block
  • rwh11385
    lance_entities
    • 18403
    alright. Bore/Stroke numbers :P
    I got all this in a simple program, plug and chug: put in the #'s, spits out the CC's:
    Bore Stroke Displacement Liters
    84 75 2494 2.5L stock i
    84 81 2693 2.7L stock e
    84 84 2793 2.8L stock 328
    85 75 2554 2.6L bored i
    85 81 2758 2.8L bored stroker
    85 84 2860 2.9L bored 328
    86.35 86.6 3042 3.0L stock 95 M3 (not sure on bore/stroke #'s, different sources=diff #)
    86.35 91 3197 3.2L stock 96+ M3
    84 86.6 2880 2.9L 328 w/ 3.0 crank
    84 91 3025 3.0L 328 w/ 3.2 crank
    85 86.6 2948 2.9L bored 328, 3.0L crank
    85 91 3098 3.1L bored 328, 3.0L crank
    86.4 75 2638 2.6L M3 pistons, 2.5L stroke
    86.4 84 2955 3.0L m3 pistons, 328 crank
    haha that's as many combos i can think of right now! Hope you enjoy..... I was really bored at work today 8)
    EDIT: when comparing say..... 85bore/84 stroke and 85bore and 86stroke:
    they are within 20cc's of each other. But compare the cost of a 3.0L crank with the cost of custom pistons, and then the benefit of being able to high-compression..... i'd go for overbore than a longer stroke.
    • rwh11385
      lance_entities
      • 18403
      Originally posted by MattM20
      theyre not as rare as you think. all 96+ (or maybe 98+) E36's (2.5 and 2.8L's) had alluminum blocks, its not just for z3's
      Hey, sorry i'm post-whoring this thread, but i love Engines!!! It must be the engineer in me..
      anyway, could one find a M50 head ala Vanos and OBDI, and swap in onto a 328 block (which would be aluminium, giving him a 2.8L aluminim OBDI motor?) And also, one could swap in 85mm pistons and 3.0L crank if desired, right?
      - - Wingnut
      • Stu Mc
        • 4083
        MattM20--
        Incorrect. The aluminum block that's M50/M52 is only in the 2.8L Z3. Newer motors (M54 or S54 or whatever) have aluminum blocks, but those are out of the question for E30 swaps.
        We did an aluminum block E30 swap 4 years ago.
        • lukasbmw
          • 651
          When did they switch to the M54's in th Z3's? 2000? Just something to remember. If you see a BMW Z3 block on ebay make sure you get the year as 2000+ blocks are aluminum but they are M54 blocks and will not work. You need a 96-99 2.8 block from a Z3.
          2004 SL600 - Current
          2006 SL55 AMG - Sold
          2004 M3 SMG - Sold
          1999 540i Sport - Sold :(
          1989 325i coupe- Sold
          1988 325is M50 M-tec - Sold :(
          • Inspar8r
            • 301
            I would have raised the red flag when there was RUST in the ALUMINUM block. Caked on from the pistons? Can't be good. Even if....
            I know Aluminum oxidizes, but damn, under what kind of circumstances have you seen aluminum rust?
            Nick
            87 325 5MT
            02 IS300 5MT
            • trent
              If I am not mistaken, the bores are sleaved.
              • JRowe
                • 352
                Sleeved block. Stock bore is 84mm can be bored to 85mm for new pistons. Rust wouldn't have been a problem.
                • lukasbmw
                  • 651
                  Gotta bring this thread back from the dead as I just found an aluminum block in a local yard. Similar situation, total price is $400. Block comes complete. Owner of the yard says the block is in working order but it has some rust.
                  I guess now I have to decide what do do. Do I want a 2.9 high reving machine, (85mm high comp pistons and 3.0 crank), a 3.1 torque monster (85mm high comp pistons, 3.2 crank) or a boosted 2.9 (85mm low comp pistons, 3.0 crank)?
                  Stu would you recomend a 2.9 or 3.1? HP/TQ estimates for each one? I think I'll go N/A for now as it will be cheaper, and lighter (A turbo system will add 40 pounds to the front and I want 50/50 balance).
                  2004 M3 SMG - Sold
                  • Rob
                    • 8166
                    if you're going NA, there's no replacement for displacement.
                    To me, coming from two low torque cars, the 2.9 would feel like a V8, however, since you already have a m50, the 3.1 may feel better to you if its an option
                    BEERTECH
                    • MattM20
                      • 641
                      Originally posted by Stu Mc
                      MattM20--
                      i'm positive the 2.5L and 2.8L M52 blocks found in the E46 are alluminum, so i was just assuming it was that way with the E36's since they were fairly unchanged except for double vanos
                      • FredK
                        • 14762
                        lukas, weren't you planning on selling your E30? I guess you just don't want to sell it!
                        Anyway, I like this thread, because it is pretty informative.
                        [edit] I just read Stu's earlier post about sourcing 85mm pistons--they'd have to be custom.
                        If you wanted to replace the steel sleeves, where would you get them?
                        FredK
                        • lukasbmw
                          • 651
                          I'm always selling my car if I get a good enough offer. In the meantime I'll buy parts if the price is right. Afterall, I could always flip it for a profit.
                          But things are also looking up for me money wise. I just started a new business venture that should bring in some nice extra income.
                          2004 M3 SMG - Sold
                          • Addissimo
                            • Mar 2004
                            • 1820
                            Originally posted by rwh11385
                            Square means the bore diameter is same as stroke length. It is the balance between long stroke -> low-revving torque machine and big bore -> high rev, high horsepower engine. This was much talked about when i was in the Honda camp years ago. When building a motor, too much stroke can ruin revability....etc.
                            from http://bimmer.roadfly.org/e30m3/mess...w18/25552.html
                            basically, high specific output from a motor requires a proper balance of bore/stroke and other factors. Many engines seek the perfect combo, like the 95 M3 was square, 86.4/86.4 i believe..... and the famous SR20DET from Nissan was 86/86. And the new Acura RSX is 86/86. See a pattern?
                            Look at the "I" and "e" engines, the I has shorter strokes, and rev like made....the e's have long strokes and are torquey.....
                            I'd say 84/84 is good, but well, that's stock 2.8L..... I'd go for 85 aftermarket, high-compression pistons and the 84mm crank..... for a high horse, high rev NA machine!
                            Or go for a long stroke, low comp, high boost monster....... just think about what applications your looking for and have a motor-builder help you...... or their sons. **cough** Stu **cough** anything he says will probably be accurate and helpful
                            i need to take a break, but i'll be back with calculations of all the stroke/bore combos.
                            What do you think the limitations of a 3.1 would be redline wise? Would 7300rpm be safe with this setup?
                            Doing something M50 related? -> http://www.addissimo.com
                            On Myspace? ->http://groups.myspace.com/r3vlimited
                            BF2142 SN = BillyGoose
                            • Budget Beater
                              • Aug 2005
                              • 230
                              S50 and S52 crank both have 91mm stroke. one has slightly larger bore. you can make E36 325 engine into M3 engine (almost same displacement) merely by swaping to M3 crank and rods. both the rods on the 3.0 and 3.2 are 135mm.
                              325 is 84mmx74mm stroke
                              328 is 84mmx84mm (square)
                              3.0 is 86mm-91mm
                              3.2 is 86.5-91mm
                              i think those are accurate as i remember from bently manual, only one im unsure about is the 3.0 but others should be right.
                              7200rpm is the max SAFE RPM you can push b/c of the hydraulic lifters, the hydraulic lifters max out at 7500-7800rpm. another reason is valve float, with high RPM valvetrain you can solve that problem. thats why you can't push the E36 motors any further. 7200rpm is honestly all the rpm you'd ever need though, S50/52 motors at 7200rpm sound heaven-like. If you do get the high RPM valvetrain for the E36 motors you CAN push it all the way to 7500rpm they safely they say.
                              • Beej '86 325es
                                • 2639
                                Originally posted by JRowe
                                I'm not Jim Rowe. I'm Jeff Rowe and I'm not related in anyway that I know of. I just happen to have the same first initial and last name.
                                That threw me off. I already sold Jim Rowe an aluminum block with 8k miles and he already knows how to build them up. ...plus I can't see Jim saying "score!"
                                -Brandon
                                '86 325es S50
                                '12 VW GTI Autobahn DSG
                                '03 540i M-Sport (sold)
                                '08 Jeep SRT-8 (sold)
                                For sale:
                                S50 TMS chip for Schricks
