Replacing my radiator in about 2 weeks, any suggestions..?
  • latinobimmer
    • 226
    As said above, in about 2 weeks I'm changing my radiator to a Behr piece (its some shitty part from Taiwan right now, leaking like hell). I have my Bentley manual, but I'm just asking you guys if there's anything I should look out for, or anything I should replace while I'm in there? I'm replacing all the hoses, eventhough they're in pretty good shape. Should I replace the little mounts on the bottom of the radiator? I heard they wear out pretty quick. Anything that might potentially break in there? Thanks guys.
    • 34847
    timing belt? water pump? thermostat?
    all would be pretty easy to get to if you're going as far as removing the radiator. although doing that is pretty easy too, don't bother with the timing belt if it's already been done :P
    • rs4pro3
      • 5808
      Pulling the fan and fan shroad first is the easist method, and make sure to drain both the radiator and block before pulling the old one out.
      85 325e 2.7 ITB'd stroker
