spring pads
  • grk325
    • 178
    spring pads
    how much are they???
    thanks
  • franz
    • 631
    about 3-4 each.
    • M42Technik
      • 9781
      Maybe you should be more....uh how do I put this...specific? More specific, yes...
      Try that.
      Reminiscing...
      • chesster6969
        • 321
        How about somebody posting part numbers for them?
        Like stock ones for post 325i's, eta,etc.
        • franz
          • 631
          Probably because just counting stock sizes there are four different ones, 2 front and 2 rear. How about the person starting the thread ask more if he wants.
          • grk325
            • 178
            :roll: calm down
            was in a rush
            fron and rear
            89 325i
            i will need them when i install the H&R cupkit
            • Bill 84 318i
              • 1600
              You can reuse your existing spring pads with the cup kit. Unless you wanna chance sizes?
              • grk325
                • 178
                cant they wore out like fell off in other words
                  • 34835
                  how the heck can your spring pads "fall off"? they're sandwiched between the springs and the mounts.. unless you drove through some acid or something and ate the rubber away! if you really did "wear out" your spring pads, I hope you're replacing every rubber peice on your car at the same time, cause they'll be in the same shape.
