Good E30 Mechanic in NYC
  • aworthybrother
    • May 2007
    • 899
    any body can recommend a good mechanic in New York City? I live in the bronx and I just bought a 1987 325e.
  • MIZTERIO
    • 993
    whats wrong with the car??
    IT IS BETTER TO DIE ON YOUR FEET THAN LIVE ON YOUR KNEES - emiliano zapata!
    • e30lyf
      • May 2007
      • 4554
      I think the car wont turn off in ignition. He turn of by releasing clutch when is on.
      - Fercy -
      Classic BMW Specialists
      Santa Clarita, CA
      www.BimmerHeads.com
      • aworthybrother
        • May 2007
        • 899
        thanks e30lyf. that is correct. engine won't stop even after switching ignition off. also, all my brake fluid is on the floor, not in the reservoir
        need to do a complete check-up as well. planning to use it as a daily driver. just got it last night. can any of you recommend a good mechanic?
        • sticksdaman
          • Apr 2005
          • 2987
          call
          Nya (nigh-ya)
          914 663 1249
          in mount vernon he hooked my shit up everytime
          Originally posted by ebelements
          Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
          • aworthybrother
            • May 2007
            • 899
            Originally posted by sticksdaman
            call
            Nya (nigh-ya)
            914 663 1249
            Thank you! Do you know the name of the shop?
            • M42Technik
              • 9781
              Visit Rohan, this is his car below:
              He's in Queens so you're not that far away...I can't seem to find the info on his shop...I have his number though, I'll PM it to you.
              Reminiscing...
              • aworthybrother
                • May 2007
                • 899
                Thank you M42Technik. Got your PM.
                • dude8383
                  • Jan 2005
                  • 10387
                  Yup I go to him as well, for shit that I just don't have the tools for.
                  Good guy, straight-up work.
                  Good prices too.
                  Tell him Denis sent you, or Sam for that matter.
                  • MIZTERIO
                    • 993
                    pM the phone # please..
                    • sticksdaman
                      • Apr 2005
                      • 2987
                      damn i wish i had a pic of nyas ride hes got a chameleon green vert wit a hard top and an s52 in it w the 5 lug swap
                      • gnarlycreature
                        • Apr 2007
                        • 233
                        eddie that used to work at msr? I don't know if he is on here.
                        • aworthybrother
                          • May 2007
                          • 899
                          Thanks for all your reply. There is a very bad fluid leak in my car. Not sure what fluid is leaking. But I noticed this reservoir is empty. Can anybody please verify if this reservoir is for brake fluid? If yes, where can I get this fluid and what kind so that I can re-fill it in order for me to drive to the mechanic.
                          • M42Technik
                            • 9781
                            Thats your ATF fluid for your power steering. My E30 requires Auto trans fluid for it.
                            Your steering rack may be busted if that keeps draining on you after you fill it up. Fill it up (do it when the car is cold, and note that when you turn it on it will fill up about 3mm more than when cold) and see if you are leaking from the steering rack under turning. Fill according to the line though, don't just pour a ton into it.
                            Also, this may be a good time to look into E36 M3 steering racks for a shorter turn-to-turn ratio. Search for it.
                            Reminiscing...
                            • bmws50b30
                              • Aug 2005
                              • 1151
                              here's a thread on adam and eddie. i haven't been there but everyone seemed to be happy with their work. they are located on northern blvd and francis lewis blvd. not sure if they are familiar with e30s.
                              i met rohan at the bmwcca autox and he now works at midas on littleneck pkwy and jericho trnpk. i've seen his cars and seemed knowledgeable with e30's.
                              1991 330is
