Anyone think this trailer hitch would work??
  • psloan
    • 9815
    The price is right - could bolt right up to an aluminum bumper. Does it seem unsafe?
  • Jscotty
    • Jan 2007
    • 2285
    Truth be told, you could bolt this on a plastic bumper and it will stay on just fine. The real issue is what you decide to attach to the hitch.
    But seriously, it would be unsafe to bolt this directly to an aluminum
    bumper. Its designed to be bolted to the step bumper of a truck where the steel is thicker and the bumper is designed to pull other vehicles. If you bolt that to your aluminum bumper the trailer is going to pull a dent in your bumper.
    • MikeE30325i
      • 2356
      if it doesnt totally remove the bumper from the car.
      and i wouldnt do it either. find something a lot more secure that will mount to something stronger.
      better to be safe than sorry.
      • backtrail69
        • Jul 2005
        • 4471
        I had something like that on my 2002, but I removed it. It bolted to the bottom of the AL bumper, then tot he rear valance and then to the floor board of the trunk. The PO just towed a very small sailboat with it.. I could see it alright to tow a jetski or track tires etc.
        :: PNW Crew ::
        '87 325 4dr, '74 2002
        • Intense
          • Mar 2006
          • 292
          So, are you not wanting my hitch? I've got someone waiting if you're passing...
          _-_-_-_-_-_-_-_-_-_-_-_-_
          Past: lots of stuff
          Present: e46 m3
          2010 F150 Lariat
          1990 E30 Touring
          1/4 e34 LeMons car
          2004 Malibu 23 LSV
          2000 Odessey Millenia 210
          • Jscotty
            • Jan 2007
            • 2285
            You could probably install a nice class 2 hitch with the slot type reciever and then cut a discreet slit in the bumper and put the appropriate size and shaped rubber plug in the hole when the hitch is not in use.
              • 37833
              Buy the hitch Intense is selling, I have the same one.
              Grover Beach, California
              BimmerHeads.com
