turbo m20......who wants to build me one?? :D
tubo m20 vs m50
Very cheap very good aftermarket engine management systems can be used in turbo applications - with all the jappa turbo technology here is it much cheaper for me to knock on a Link Engine management (to replace L-Jet) and get a couple of turbo parts from a Skyline and build a 140 rwKw e30 (at 11 lbs boost). (This is on my m20b20)
It would cost twice as much to do an m50 swap - and you'd get a whopping 100 kW at the wheels.. wow.
Check out http://www.link-electro.co.nz/home.html .Comment
How much was the running m50 car?Originally posted by BrysonRobert, if you start with a post 88 325i the swap can be done for under a grand. Mine's about 2k with an alu flywheel, m3 clutch, new used tranny, and various mantenance parts, this and the car i bought with the m50 was running
I wish I could pull off a m50 swap for under a grand :P
turbo m20
my e30 m20 turbo's been running for 15 months w 24lb injectors, intercooled, 240,000 miles on stock engine with stock engine managment. Many thanks to Todd at TCD for sharing tech advise!!Comment
Why would anyone waste their time on an M50 swap? If you're going to that much trouble (remember, you're probaby going for the whole E36 driveline too, not just the motor), why not go with an S50? And comparing a stock S50 to a turbo M20 might be a closer comparison.
If it were me, I would look at budget and legal issues (like, will a turbo M20 pass your local smog laws, etc) first. I have a feeling that doing so would allow the decision to make itself.
But what do I know? My sole engine mod is a Conforti chip.
ScottComment
All I used was the m50 motor.. everything else from the e30.
m50 motor swaps are legal here in cali and home made turbo's aren't, so that's obviously a large advantage for many people, good point Scott
edit: to add to my first statement, we just did an s50 swap for a local friend using an m20 tranny/flywheel/clutch/driveshaft setup. And they're also not very difficult swaps, go BMW 8)
I'd be interested in hearing how you dealt with the odd tilt angle when you hooked up the E30's transmission to the M50. I bet it gave you a whole new "slant" on life, eh? :DOriginally posted by BrysonAll I used was the m50 motor.. everything else from the e30.
ScottComment
You simply make your own tranny support bracket. No big deal.Originally posted by bimmerscottI'd be interested in hearing how you dealt with the odd tilt angle when you hooked up the E30's transmission to the M50. I bet it gave you a whole new "slant" on life, eh? :D
ScottDon't forget the good things Hitler did.Comment
