Whoa, big truck drifting
You guys see what those crazy brits do? Those psycos race those things like BMWs.Im now E30less.
sigpicComment
WOOOOOOW :o
I think that's a MAN F2000 V10
it's just an 18.3 liter V10 engine that produces an awesome 440Kw (600hp)
and an famous 2800Nm torque 8)
It's the most powerfull truck engine in Europe
1989 E30 318iS
_______________________________1989 E30 325iC M-Technic I
1997 E36 328iT
1990 E30 325iT 24v SOLD
1989 E30 325i 2.7i M-Technic II SOLDComment
Here in the US, Caterpiller puts out an inline 6 cyl with 660hp and 3400 ft lbs of torque. Cummins has one very similar. I don't know what they use in Australia on their "road trains". It is probably even larger.Originally posted by BavarianBimmerI think that's a MAN F2000 V10
I have not seen the European truck racing on TV in a couple of years. It sure was fun to watch.
The cab is on a suspension of it's own separate from the chassis. Will it tip, yes, unless you hit the corner right and get the tires to slide (fronts and rears). Some of our standard truck tires weigh over 220lbs each. Include 4 tires, steel wheels, 50lbs of lug nuts, and a huge differential/axle assembly and it gets pretty heavy pretty quickly. Some of the smaller single axle 'day cabs' weigh as little as 8,000 lbs. The more standard road truck can weigh as much as 20,000 lbs depending on the setup (no trailer). Some of our road trucks with a trailer weigh in the neighborhood of 37,000-43,000 lbs empty weight (moving vans).Don't forget the good things Hitler did.Comment
Originally posted by RedBaron86325Here in the US, Caterpiller puts out an inline 6 cyl with 660hp and 3400 ft lbs of torque. Cummins has one very similar. I don't know what they use in Australia on their "road trains". It is probably even larger.Originally posted by BavarianBimmerI think that's a MAN F2000 V10
that Caterpillar is an 4 valve/cil. engine ?
Can you convert 3400 ft/bs to Nm ??
I can tell you 660hp is in Euro norms very big ('cause euro things are just smaller)
In my company the biggest truck is an Mercedes Actros with an V8 and has 570hp
1989 E30 318iS
1997 E36 328iT
