Found leaking brake line, need some help.
  • e34 530
    • May 2007
    • 62
    Well I traced down my leaking brake line and now it's the last item I need to fix to get my e30 roadworthy. I tracked it to the main line that goes into the "t". I was looking at the realoem diagram and was confused by it. Anyone got the part number for that line and does it go all the way up to the master cylinder? Thanks for your help, Andrew
  • s0urce
    • Dec 2004
    • 2933
    Jesus Christ....that needs some TLC.
    tasty
    • blunttech
      • 12850
      that car had to be owned by jonny at some point.
      dude , if that were my car id be looking at more than the t and that one line. id go thru the entire brake system.
      sales@blunttech.com
      www.blunttech.com
      Like us on Facebook
      • Teaguer
        • Sep 2004
        • 6167
        Man am I glad I live in the souf .
        • e34 530
          • May 2007
          • 62
          truf, anyone have the part number?
          • Teaguer
            • Sep 2004
            • 6167
            Main line : #34326755686
            T-fitting : #34341111435 .
            I think your chassis and suspension bits are made out of spit and leaves . :D
            (heard one of the TopGear guys say that recently) :rofl:
            • e34 530
              • May 2007
              • 62
              # 34341111435 .
              thank you sir. I may wind up parting this car out
              Just wanted to use this smiley...:hitler:
              • parkerbink
                • Jun 2004
                • 10138
                http://www.realoem.com/bmw/partgrp.d...08&hg=34&fg=15
                http://www.realoem.com/bmw/showparts...53&hg=34&fg=15
                • Mike325
                  • Mar 2006
                  • 3685
                  Man, that rust is almost frightning. I would take a good hard look at the whole underside of that car. The rust seems to be pretty well set in that car. You will most likely need a new pressure regulator because the line will be hard to get off of there. I replaced this line on my car and this is what I did. I would get a good look at your rust situation before you replace the line.
                  Originally posted by Kershaw
                  • e34 530
                    • May 2007
                    • 62
                    yeah the rust is pretty bad since the owner lived right on the beach, but I bought the car for a beater so I don't ruin my e34. The rust on the diff is just surface form the leaking brake line. (It's an LSD, zomg!) It's only getting used about twice a month and I had it up to 50 mph and took some swerving. Plenty of bodyroll but nothing broke so I'm happy lol.
                    • e34 530
                      • May 2007
                      • 62
                      Thanks again, what about the 2 small lines that run from the "t" to each rear wheel? Thanks again, Andrew
                      • e34 530
                        • May 2007
                        • 62
                        Also, while we're making fun of my car can someone tell me what this wire was orginally for? I'm guessing e-brake sensor?
                        • FredK
                          • 14762
                          Good lord. That is some HAIRY looking shit right there.
                          • FredK
                            • 14762
                            The brake pipes that go to the rear are
                            34326755567 380mm line
                            34326755559 300mm line
                            • parkerbink
                              • Jun 2004
                              • 10138
                              Sorry if the links were insufficient
                              No. Description Supplement Qty From Up To Part Number Price Notes
                              01 BRAKE HOSE REAR L=222MM 2 34321159878 $25.95
                              02 BRAKE HOSE REAR L=200MM 2 34321159881 $23.44
                              03 DISTRIBUTION PIECE M10X1 1 34341111435 $7.25
                              04 BRAKE PIPE BRACKET 4 34301161567 $0.67
                              05 BRAKE PRESSURE REGULATOR 1 34331152494 $111.70
                              06 CLIP 3 34341163565 $0.89
                              09 PIPE M10/M10-360MM 1 34326755565 $7.04
                              10 PIPE M10/M10-3120MM 1 34326755686 $16.18
                              11 PIPE M10/M10-380MM 1 34326755567 $7.04
                              12 PIPE M10/M10-280MM 1 34326755557 $5.30
                              13 PIPE M10/M10-740MM 1 34326755590 ENDED
                              13 PIPE M10/M10-751MM 1 34326755591 $4.41
                              14 PIPE M10/M10-740MM 1 34326755590 ENDED
                              14 PIPE M10/M10-751MM 1 34326755591 $4.41
                              15 BRAKE PIPE BRACKET 1 34321158467
