Anyone heard of JBR Lightweight Flywheel ? ***New Questions*
  • nitro325is
    • 495
    Found a decent price on this flywheel.Has anyone heard of this JBR Lightweight Flywheel? Any experience with this flywheel?
    Its a 8 lbs 228mm.
    here is their sales pitch------
    We offer the most extensive flywheel listing for BMW applications that is available in the market and we are continually expanding our line to include the latest models. The following flywheel listings are designed to replace stock dual or nondual mass flywheels and to be used with the stock pressure plate and clutch assembly for the model listed unless otherwise noted. Our "ULTRA-LITE" competition only flywheels and flywheel/clutch packages custom designed for ultimate performance are available for many popular racing applications. Our flywheel kits include: CNC Machined Aluminum Flywheel, Ignition Triggers where Applicable, Dowel Pins, Helicoil Inserts and Pressure Plate Hardware, Replaceable Hardened Steel Clutch Disc Friction Surface, Starter Ring Gear - Heat Shrunk & Bolted-on, Hardened Flywheel Bolt Ring w/ Premium Grade Mounting Bolts. All Flywheels are Zero Balanced.
  • e30sd
    Fistee
    • Jan 2004
    • 5517
    jb racing is the new name for mpd racing. they make great pieces, turner sells their stuff. i believe trent has one too...
    • schnitzer teil-jäger
      • 661
      NO LINK, NO PICS, GONNA MAKE US SEARCH?
      W
      • Bryson
        • 1490
        I have one of their flywheels, I don't believe that trent is using one yet. I can tell you that it looks absolutely gorgeous, more so than ground controls, for comparison. It's light as fuck and looks to be very well constructed. As soon as I get the car running with it, I'll be able to make further comments on it
        • e30sd
          Fistee
          • Jan 2004
          • 5517
          bakaw!
          i've driven a 330is with the 10.5 fly, as well as a 318ti clubsport with an 8 lb fly, and i liked em both. took a few minutes to get used to the revs dropping so quickly, but after that, rev matching became teh fun :twisted:
          • nitro325is
            • 495
            Does anyone here actually have a lightweight flywheel installed on an M20? I do mean less than 10 lbs.I keep reading horror stories on crappy low erratic idle (dont really care about that) and about the engine stalling as soon as the clutch is depressed after high revs unless you pat the throttle.Although most of these stories are from e36 owners.
            Is 8 lbs too light for a moderately modded M20? I keep hearing 10 lbs is best yet no one offers one.
            Also since Im going to be using an SMT-6 soon should I forget about sending my chip to get remapped for a higher idle? In other words would the Smt-6 allow me to adjust the idle?
            • Jand3rson
              • 37587
              Not to hijack this thread, but will a single mass 325i flywheel work on an eta? If it does, I will either pick up one of these (see, not a total hijack) or have the one in my parts car lightened.
              • e30sd
                Fistee
                • Jan 2004
                • 5517
                my friend with the clubsport had idle problems, but after a few days, the DME adapted and accounted for the new fly. the 330, on the other hand, received a tms burned chip with bumped idle. either way, neither car exhibits flaky idle behavior anymore.
                • Jordan
                  • 12916
                  It will bolt on, but the car wont ever start. It lacks the trigger to give the pulse sensors the readings they need.
                  https://mtechniqueabs.com/
                  • Bryson
                    • 1490
                    mine's on an m50 :oops: sorry, it's the one made for an m20 though .. 8lbs, I'd say it's fine for an m20.
                    Don't bother with the chip, SMT6 isn't that much more than one anyway, with that group buy through Gunni, ends really soon IIRC though
