how hard would it be....
  • mudflaps
    • 808
    to cut an engine block in half? what about a camshaft? crankshaft?
  • mode
    • Jun 2007
    • 140
    With the tools that I have, it would be very easy. Friction saw. 15000 feet per minute. (tooth speed)
    • mudflaps
      • 808
      owch, sounds like some damage.
      im thinking more along the lines of something made by milwaukee, starts with an "S", rhymes with awzall
      jk, im thinking more along the lines of a plasma cutter/air cutter?
      • rede30
        • 4697
        dope coffee table?
        • mudflaps
          • 808
          Originally posted by rede30
          dope coffee table?
          :pimp:
          dope tons of shit. pics in a month or so.
          • AlarmedBread
            • Sep 2006
            • 1510
            Big bandsaw :D
            • mudflaps
              • 808
              Originally posted by AlarmedBread
              Big bandsaw :D
              maybe. something tells me im gonna go through alot of blades.
              • Mike325
                • Mar 2006
                • 3685
                LOL, I am doing the same thing with my eta motor when it comes out in a few months. Crank shaft lamp anyone?
                Originally posted by Kershaw
                • AlarmedBread
                  • Sep 2006
                  • 1510
                  I use my cracked block as a 6pack cooler....
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    There's no way to cut a block with anything that isn't a continuous blade saw. I.E. - A plasma cutter won't work because it only cuts up to a certain thickness. Same with any kind of air cutoff wheel. You won't be able to cut deep enough.
                    Best bet would be a BIG band saw. Keep it well lubricated and giver her hell. ;)
                    As far as a camshaft or crank, are you talking about cutting it lengthwise, or widthwise (shorten it)? The only hard part I see about cutting it lengthwise is clamping/holding it in place, given it's awkward shape.
                    • payney8
                      • Jun 2007
                      • 899
                      yeah more info?
                      • cactusjacks1
                        • Sep 2004
                        • 1216
                        Water jet machine - 50,000 psi, cuts like a laser
                        [I
                        • mudflaps
                          • 808
                          i bet, ever put your hand in front of a power washer where the water comes out? I did that once accidentally and it cut my hand, and im pretty sure that was only somewhere around 2000psi.
                          • psloan
                            • 9815
                            Pressure washers are no joke. Especially when you have a "0" nozzle. I used to work at an apartment complex and powerwashed a hole in the parking lot all the way into the dirt. lol. I think it was something like 3500 psi hot water.
                            • Jscotty
                              • Jan 2007
                              • 2285
                              You should have gotten that checked out. Pressure washers have a warning about that because the potential of forcing air into your bloodstream is very likely in the event that you pierce the surface of your skin. My pressure washer even has a card that you are supposed to take to the emergency room with you so that they know exactly what you shot yourself with.
