Could it be possible that I have one?
Bought this motor used with 99,000 miles. It had what appeared to be a noisy top end so I had it rebuilt. I had the shop drill and tap a broken timing belt cover bolt and they found it to be 0.040" off center from the camshaft. They had to plug the original holes and re-drill and tap them. Noise persisted so I pulled the head head again and had it checked. No problems with the head but I still had the same noise after install.
Next, I pulled the pan and the IE crank scraper only to find the the crank was walking about an 1/8 of an inch ( nice grooves in the scraper )
The motor is quiet at idle and while cold. It only occurs above 1700 rpm and when you lift on the throttle.
Any ideas what could cause this?
Keith
Keith
