What do I need to install euro bumpers? I bought a set but with no brackets/valences. I know where to get the valences but don't klnow if they are needed.
Thanks in advance
Here is some links for the part numbers for the brackets that you need. Just call whoever you like to get your parts off of and order some or you can make your own.
No cutting needed. According to RealOEM BMW sells front and rear sets of mounting components needed. Off the top of my head I remember the RealOEM price for front mounting hardware is $45 and some change, so the actual price now should be about that.
You'll have to drill 4 new holes for the back bumper. And for the front you'll have to modify the wire connector for the turn signal cause euro bumpers don't have parking lights only turnsignals. I cut the end part off of mine that had the parking light wire in it, then i shaped it to fit into the turn signal connector in the light on the bumper.
There was a guy over on e30 tech that wanted to run the early is air dam with euro bumpers, but i don't know if he got it to work? Propobly have to use the metal valance with the 86-87 lip.
