Introducing: Interior light delay dimming...
  • Mtriple
    • 3139
    I'll take one. Paypal?
    Originally posted by Simon S
    • E30 Reaktionär
      Site Manager
      • 14451
      I'll take one. My 85 turns off after 10 sec. and it's kind of sucks.
      1992 BMW 325iC
      1978 Chevrolet Monte Carlo
      • george graves
        • 20003
        Looks like I'll need to put a cap on the first group buy. I may limit the number of units to 20. (These are being "built to order")
        When I've reached the limit for the initial group buy, I'll send you my paypal address via PM.
        After the first 20 slots are filled I'll start the second GB, and let you know when to paypal me.
        Originally posted by Matt-B
        • 87Blue325iC
          • Apr 2006
          • 1111
          The stock relay is located below the speaker on the driver side foot well. Basically, you remove the kick panel, and then pull the speaker out, replace the relay, and you are done.
          Hmm...what happens if you have non-stock speakers with bigger magnets, could there be a clearance issue?
          Aaron
          • Funkmasta
            • May 2004
            • 7185
            I want one, but, how long will it be until your next batch? My car is down for the count, so I dont need to take one from someone else, but I will def cut in line if your next batch is over a month away. ;) lmk
            Joe Funk -- Portland Oregon
            That Guy.
            03 X5. 3 liter obviously.
            • e304me
              • Feb 2006
              • 1374
              so could i get one that has the lights dim slightly slower after turning on? just the rate at which they dim
              • george graves
                • 20003
                Not a prolbem - The relay is *below* the speakers, not behind it.
                My plan is have 20 ready to ship by Monday - that's the plan anyways. I'll be placing a larger order for parts (each unit contains over 20 parts) and get that next day - so hopefully I can say one step ahead of the demand. I'll glady take down names for the next batch, but I will not accept paypal untill I have the first batch done. I'd rather not have angry customers.
                Not at this time. I may lengthen the "key on" delay time very slightly before shipping this batch. I'd be interested in what other have to say. You really don't want it on for very long - and believe it or not, when you are in a hurry, a few seconds is a LONG time.
                • Jonathan M3
                  • 1837
                  Do the lights come on when you turn the car off, like the newer models? I like that feature on my E36.
                  '05 E46 M3 Imolarot/Cinnamon - CURRENT
                  '98 E36 M3 Estorilblau/Dove - SOLD
                  '90 E30 M3 Brilliantrot/Black - SOLD
                  SRS BSNS Motorsports - 24hrs of LeMons Racer
                  • e304me
                    • Feb 2006
                    • 1374
                    oh yeah that exactly what i meant i think. when you turn the key on it dims at a slightly slower rate
                    • apprentice
                      • Jun 2006
                      • 103
                      I'll take one.
                      • george graves
                        • 20003
                        Originally posted by dlmrun2002
                        I'll take two. I have two cars but might pass one on to a buddy if he likes. Now if only you could wire it into the rearview mirror lights as an alternate source..
                        If you want to wire it in you can. Last night I started testing to see how large of a load that this will work with "in the real world" testing. I had 3 large break light bulbs all running off of it at once before I blew the fuse on my benchtop power supply. :(
                        No it doesn't.
                        GB list updated.
                        • UNHCLL
                          • 8790
                          According to the ETK, this will work on all e30's except 1992's, and car's with heated door lock handles. With that said, you could still adapt it to work, but it would not be "plug-and-play" AFAIK
                          M3's have heated door handles, as do most 325is'....
                          Below the radar...
                          • george graves
                            • 20003
                            Well if that is true, than that is not a problem. I have it installed on a 325is, and according to BMW's electrical diagrams, the only time they changed the wiring is on 92 e30. (in 92 they removed the relay all together)
                            So, if you have the relay, you're fine. Every e30 I've seen has them.
                            To check to see if you do with out removing anything, go out when it is REALLY quite, and stick your head about where the speaker is. Then with a finger push the switch on the door jam. You should hear a very quite "click" from the relay.
                            • e30_kid89
                              • Apr 2006
                              • 489
                              george quick question regading the unit - in 2 of the previous e30s ive owned ive seen the relay socket there you speak of with no relay plugged in ever, so would your unit just plug in there and work from the get go?
                              after i do up my audio, i gotta get me one of these.
                              • e304me
                                • Feb 2006
                                • 1374
                                it seems like that should be easy to add since there is already a function for key on. just add one for key off? i would think it shouldnt be too hard? idk that would really be nice to have though
