after market cam question
  • german g
    • Feb 2006
    • 1608
    What is a good street/maybe slight track use ,aftermarket cam?
    I'm not very educated in the degree of cams and such, enlighten me:-)
    90is, longtube headers/straight pipe/mark d 18# 93 0ctane chip/18# injectors/vogtland springs/bilst. sports
    :firehop:
  • egk2
    • 2426
    Stock m20? 272 I suppose would work nice.
    I ran a BMP 282/272 dual pattern camshaft but my m20 wasn't stock,
    had a pretty lumpy idle.
    • Rigmaster
      • 3464
      stock.
      Unless you just ABSOLUTELY have your heart set on a cam, and have a good reason to run one- just stick with the stock cam.
      There are lots of other things to do the free up HP that won't make the car unpleasant to drive on a daily basis.
      Bret.
      • E30 Reaktionär
        Site Manager
        • 14451
        I never had a cam'd up 6cyl before. But i did have alot of V8's with different cams. I did have a daily driver with a .520 lift and a .305dur. But the idle was really thumpy, but i like that kind of stuff. Nevermind i did had a cam in a 6cyl. before. A Crane Cam in a 2.8 v6 s-10. I don't remember what size it was though.
        1992 BMW 325iC
        1978 Chevrolet Monte Carlo
        • german g
          • Feb 2006
          • 1608
          the only mods, besides suspension, are mark D 93 octane 19# injector chip, 19 # injectors/ M30 AFM / bav auto longtube headers, straight single pipe exhaust...
          My freind was running a shreik cam in his e30, but engine was bored out..It ran great..
          So a cam wouldn't really help without engine work or what? What else do you guys suggest, I want some more power!!! (with out swapping another engine)
          My M20 only has right over 100k on it, so I'd like to keep it, and really dont wanna boost.
          give me your opinions guys
          Thanks
          I like thumpy:-)
          :firehop:
          • E30 Reaktionär
            Site Manager
            • 14451
            A small cam will help but you may need stronger valve springs and maybe rocker arms, but if you want to go bigger then you'll need to do some port work and maybe bigger valves.
            1992 BMW 325iC
            • egk2
              • 2426
              I wouldn't bother with a cam in a stock m20 personally but if you want to run the 272, it still idles smooth but you'll need dual valve springs.
              You've pretty much covered all the bolt ons, not much more you can do
              besides FI.
              What diff are you running?
              • der affe
                Technical
                • Dec 2005
                • 8452
                i agree, your next step is to decide if you want to step up to ITB's and stand alone EMS. then you throw big $$ at your car for not so big HP returns. ITB's and EMS can deff help smooth out the whole package and let you run some monster camzilla action and keep it livable for daily driving. if you do the cam swap go ahead and get a spare head have the headwork done to match your cam choice (not just hog it out) then you can swap the complet head and cam on and go. even if you stay with your stock intake system and mark D chip with the P&P head abd cam you will get some nice results. when you decide what your combo will be i'd talk to mark D about burning you a chip to fit the new combo also, that way you can max power out of it.
                • german g
                  • Feb 2006
                  • 1608
                  thanks for all the replies guys,I guess I'm leaning towards the 2.7 liter stroker, now I gonna need to source me some eta parts :-)
                  :firehop:
                  • Jonathan M3
                    • 1837
                    I would suggest a MAF conversion.
                    http://millerperformancecars.com/catalogue/10.html
                    '05 E46 M3 Imolarot/Cinnamon - CURRENT
                    '98 E36 M3 Estorilblau/Dove - SOLD
                    '90 E30 M3 Brilliantrot/Black - SOLD
                    SRS BSNS Motorsports - 24hrs of LeMons Racer
                    • german g
                      • Feb 2006
                      • 1608
                      http://millerperformancecars.com/catalogue/9.html
                      interesting, I havnt seen that...anyone use this MAF before? I guess it would mean removing my 19#/93oct. Mark D chip?
                      :firehop:
                      • der affe
                        Technical
                        • Dec 2005
                        • 8452
                        i have the BMP one (which is from a 96 T-bird BTW) i have hear it is possable to wire it into the factory ecu somehow. with mine you have to run a piggyback to make it work. i have heard that it doesn't give you huge gains for a fair chunck of change though. my car came with it and the dbilas ITB's so i can't tell you if it made a big difference though.
