so is there any possible way of getting an s50 into an ix? just curious... i mean im sure there would be some afro engineering involved...but just wondering about the possibilities. Or would it be better just to build the shit out of my M20?
s50 in an ix????
:: PNW Crew ::
'87 325 4dr, '74 2002 -
A nice low boost setup would be fun... and probably cost less.:: PNW Crew ::
'87 325 4dr, '74 2002Comment
There is one way to achieve an S50 swap into an ix: rip out the entire AWD running gear and live with RWD. A local guy did this to an '89 some time ago. I saw it up on a lift at a friends' shop when the project with about 80% complete.
If you want to retain AWD yet increase power, better think about the boost option. I'd go conservative if you do - I don't think the AWD system was engineered with big HP in mind.
JonRides...
1991 325i - sold :(
2004 2WD Frontier King Cab
RIP #17 Jules BianchiComment
so i have 193k on my engine right now. the head was rebuilt about 50k ago. What would be a safe way of getting boost on this car and maintaining a degree of reliability? And for the record, my front diff is out right now. I dropped a ring gear so i just took out the front drive shaft....so currently im RWD.
How can an M20 not fit?Comment
The block is different? Didn't know that.
I can see the oil pan being different for sure.Comment
safe way would be drop compression via thicker HG. if alot of the exhaust side parts are different i.e. motor mounts etc. you might have to have a exhaust manifold custom made. id consult the F.I. section on Bimmerforums, those guys know ALOT.so i have 193k on my engine right now. the head was rebuilt about 50k ago. What would be a safe way of getting boost on this car and maintaining a degree of reliability? And for the record, my front diff is out right now. I dropped a ring gear so i just took out the front drive shaft....so currently im RWD.Comment
