I left the key turned forward on my car while I was working on it so now my battery is dead. I have another style battery that I was going to use to start the car, disconnect it, and then while the car's running connect the dead battery so it will charge when I drive around. I won't fry myself as long as I disconnect the negative first, right?
safe to do this?
Pushstarting it actually works quite well. Get a couple people to push, fifth gear, drop clutch, have key over in ignition, and it roars to life. Just release the clutch right away!- Sean HayesComment
^Yes, as a matter of fact I have. :)
Bump start FTW, I bought a (cheap) car that was a non starter, had a battery cable fuse popped, I bump started it and drove it to the store to buy a fuse. I felt a little bad, but hey.
In theory it will work and you will not fry yourself. I have done this on other cars that I have owned and never had a problem. The only thing that I don't know is whether or not you will fry your computer. BMW electronics are somewhat "fragile" and if you do something that is seemingly harmless, that could be the one thing that creates an electrical gremelin in your car.
I had an incident where the fuse kept blowing on my right side tail light and before I was able to troubleshoot the problem, I decided to just simply jump a wire from the left tail light over to the right tail light. After that I had nothing but problems with the car starting and running. Once I was able to find a new computer, the problems went away. Could this have been a coincidence? Maybe but I heard a similar story on bimmerfourms where a guy said that he did the same thing with his dashboard lights and then had computer problems.Comment
5th gear! Jesus. I do it in 2nd.
No money? Go get metal coat hangers and some duct tape, bam! Instant jumper cables.sigpicComment
lol
