Intakes
  • JK_E30
    • Jan 2007
    • 545
    Don't let it get to you... It's a prerequisite for r3v... Your supposed to feel stupid. It's the method for weeding out the lame-o's I hear you gotta survive for a year or two. That, or, don't post...
    well ya, thats why I expected a few "oh great idea" and all that, but all in all just wondering, think ill just take a look at it myself, see what I can come up with.
    M50B25tu
    • ///Mayhew
      • May 2007
      • 285
      well heres a idea for you, it was acutually what i was plaining on doing. I have a M10 motor so i dont know if you have the same amount of space, but anyway i was goin to run the pipe down on the inside of sub frame to the splash pan, and then out infront of the left front tire i had the hole cut and all but i too was worried about sucking up all the water. I dont know if my description was that good but if you want pm me and i can take a pic of where i mean. Also heres a web site to help you get parts so you dont have to goto a shop and pay out the a$$ for fab work. http://www.turbohoses.com/ Good luck
      1989 325i MT2/4dr
      My life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather i will skid in broadside,thoroughly used up,totally worn out and loudly proclaiming....WOW..What a ride!
      • dlmpsy
        • Sep 2006
        • 189
        Originally posted by dinanm3atl
        I must be REALLY lucky!!!
        My m3 has the dinan intake and it is inches off the ground behind the driver side tire just above the brake duct...
        60,000 miles! Lucky me!
        Hopefully your engine won't turn into a wet/dry vac when a good thunderstorm passes by, perhaps Dinan built in some type of bypass for the incidental splash of water.
        • german g
          • Feb 2006
          • 1608
          the stock air box is better.
          90is, longtube headers/straight pipe/mark d 18# 93 0ctane chip/18# injectors/vogtland springs/bilst. sports
          :firehop:
          • clavinZERO
            Hella sick E30
            • Mar 2004
            • 2027
            Someone should post a link to that test some guy did dealing with the flow of a stock filter vs. an aftermarket filter. I believe, and many will recall, the OEM paper filter was the best setup. Most people will also say that the factory box /short-snorkel setup is the best for performance; but man, if you get this long-tube thing working--- I bet it will sound mean as hell.
            "BMW Style 32 Poster-Child"
            HTTP://WWW.CLAVINZERO.COM/e30-5-lug
            **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
            • Ablice
              • Sep 2006
              • 261
              Open your hood. Stare at the airbox and AFM.
              Ask yourself: Can I design a system better than BMW engineers did on this bueaty?
              :mrgreen:
              Like game music? >clicky<
              • gearheadE30
                • Jun 2007
                • 3734
                Normally, CAIs don't do anything, but taking air from the brake duct would definitely do something once the car is up to speed. The intake pipe would have to be quite large to maintain smooth airflow, though. I have an M42, so it may be different, but I think the best way to do it would be to run a pipe out of the stock airbox on the engine side and then run it down to the duct. BTW remember that it will be LOUD sucking air through the duct and valence.
                Project M42 Turbo
                • rThor432
                  • Feb 2007
                  • 3907
                  Yep you are right. The OEM paper filter setup flows the best. The only reason to go to a K&N style "rechargable" filter is if you dont plan on changing your filter at the regular (12k I believe) interval.
                  • uofom3
                    • Jan 2004
                    • 5392
                    stock is the way to go in the intake side.
                    PNW Crew
                    90 m3
                    06 m5
                    • DrewO
                      • Sep 2007
                      • 12
                      cai
                      If i recall, a cai in Phoenix = close to 200 dergree air temp from off the black top. I think the best setup is the ram air intake through the left high beam.
                      I also know several Honda guys that hydrolocked their engines in AZ using a true cai from AEM or whatever (no bypass valve).
                      If you are going to use a cai I strongly recommend using an air bypass valve to
                      prevent hydrolocking your engine.
                      Bypass valves are about 40$$, good used engies are about 1000$$
                      • JK_E30
                        • Jan 2007
                        • 545
                        Yeah, not sure if I am going to do it but idk.. i might.
                        M50B25tu
                        • JK_E30
                          • Jan 2007
                          • 545
                          Yeah I didnt really think about the black top thing. thanks for that!
                          and yeah 40 is nothing. lol
                          M50B25tu
                          • Addissimo
                            • Mar 2004
                            • 1820
                            I'd say stock...
                            it will be a whole lot of work for something that won't really work in the end.
                            Get a mark d chip instead.
                            /thread.
                            Doing something M50 related? -> http://www.addissimo.com
                            On Myspace? ->http://groups.myspace.com/r3vlimited
                            BF2142 SN = BillyGoose
                            • Digitalwave
                              is a poseur
                              • 6300
                              Why will putting it in the brake duct "definately do something"? The guy that tested the theory of ram-air intakes found that at 100mph, a ram air duct is making like 0.01 psi of boost. You really think you are going to feel that?
                              With the heat soak the filter is going to experience down low near the baking Arizona concrete/asphalt, you are definately going to lose power with that setup. Intakes are just a no-no on M20's. But do it if you want, it will be stunner on your all-stock E30!
                              RISING EDGE
                              • blunttech
                                • 12850
                                get deagle to design something for you if hes not working for ptg by now
                                sales@blunttech.com
                                www.blunttech.com
                                Like us on Facebook
