f#$&%$ my clearcoat
  • new2bmw
    • Oct 2006
    • 387
    f#$&%$ my clearcoat
    car was painted wednesday, thought it would be hard enough to put a soft blanket over fender while working on engine. No, when i took the towel off the clear had the fabric imprinted in it and had no shine, like it had been pressed down to the base coat. am i pooched or can this be fixed? help please
  • BeirBrennerE30
    • 2740
    you can try wetsanding it but your probably screwed.
    e30sport.net
    '06 M3 Competition - 6-speed
    '97 Range Rover Vitesse
    • new2bmw
      • Oct 2006
      • 387
      screwed
      should i wait for it to cure before doing anything? its a spot about 4 inches by 3 inches. what would i do to fix this? and when you say screwed what exactly does that mean??????
      • Bill-B
        • Apr 2007
        • 1242
        It means you are F^cked
        Originally posted by NavyE30
        I saw Vlad was posting and got excited. Then I saw there weren't any boobs and was sad.
        • new2bmw
          • Oct 2006
          • 387
          so what?
          does the whole fuckin car need to be reclearcoated or can that spot be fixed????
          • Tavern Gnome
            • 2137
            I cant believe the clear is still soft! I'd try to wet sand it with 2500 grit and buff it out, otherwise just have the screwed up panel respayed. Tell your painter to bake his paint jobs...geeez
            __________________
            1987 Toyota Landcruiser V8
            • Jordan
              • 12916
              You don't need to do anything. Drop the car back off at your bodyshop and ask them to repair that area. Easy to reclear one area and bill you for it.
              https://mtechniqueabs.com/
              • new2bmw
                • Oct 2006
                • 387
                clear
                wont be able to do anything till at least tuesday, is there any rush for this or can i just take it when i get a chance. only reason i ask is because i dont know if i need to get it there befor it totally cures or not.
                • atomic
                  • Jun 2007
                  • 5691
                  once paint has curred since they did not bake the paint, you can wetsand and buff out but I highly recommend you not do it if you have no clue in what your doing. You can easily screw it up even once curred and if is that soft now forget it. You will just makes things alot worse
                  • new2bmw
                    • Oct 2006
                    • 387
                    paint
                    so no rush then, let it cure then take it to the shop. how long am i looking at for it to cure if its not baked?
                    • Tavern Gnome
                      • 2137
                      even if it didnt get baked it should still be cured if it was painted on wednesday! must have used really cheap clear or not enough hardener. Thats strange.
                      __________________
                      • Jscotty
                        • Jan 2007
                        • 2285
                        I think you ought to take it back to the shop, tell them what happened and ask them to fix it. I am sure that any reputable body shop would appriciate knowing that that their clearcoat is still soft after a week. Also I wouold suggest that they wouldn't mind fixing it being that they know what to do about it and they wouldn't want their work to be misrepresented by your attempted repair.
                        • atomic
                          • Jun 2007
                          • 5691
                          X2
                          • new2bmw
                            • Oct 2006
                            • 387
                            i will
                            I am going to take it back to them for sure. I would never attempt to fix it myself. I was just curious what it would take to fix it. i am hoping it wont need to be taken down and new color coat and clear put on. Is it possible for them to just shoot clear over such a small area to repair it? Its on the top of the passenger side front fender and its about 5" by 4". Holy shit I am mad at myself for putting the blanket over, this has been a 2 year project and a lot of hard earned cash and i go and fuck up my paint.
                            • atomic
                              • Jun 2007
                              • 5691
                              Dont be so hard on yourself over it as the shop should have baked the finish on where this would not have been a problem at all... They either did bake it but no where near long enough or they didn't bake it at all. It should be a fairly easy fix for them and might not even have to be reshot either....
