So I went to the bodyshop today. (UPDATE PG. 2)
  • Jordan
    • 12913
    As many of you know I am far from entirely satisfied with the original respray done on my e30. I went down the the bodyshop today to work out a solution to the problems.
    (list of problems is at end of post)
    I talked to the manager who did infact remember me and my car well, which was helpful. He was actually very reasonable and I think we will be able to find a suitable middle grounds to meet concerning billing for the cars soon to be complete respray in the same color. He was quite willing to warrenty thier work to a point, point being basicly fixing, repainted, and blending the areas that are worked on. Blending isnt acceptable to me, so the entire car needs to be repainted.
    Hopefully what I am looking at for a bill is.... full bill for the bodyparts I have added since they painted it. Partial bill for materials used to paint whole car (beyond that needed to do spot blending repairs)
    I told them I need to have the car back and done by late June, hopefully around the 20th. That would give me 6 days to reassemble the car, and drive it up to the Pacific NW e30 picnic where (if I make it) my e30 will be a featured car 8)
    I took this list of problems with me.
    General notes of imperfections and flaws, concerning the body/paint work done on Jordan Sarette’s 1987 BMW 325iS by B&R Paint & Body shop.
    Location: Over the entire painted surface of the vehicle.
    Description: Note this is not referring to the texture “orange peel” in the clear coat. This is in reference to the texture in the base coat. It looks as if the spray gun “spraying chunks” of paint on the car. The base coat should be perfectly smooth in appearance. It is most certainly not.
    Description: I had the key locks filled and shaved off. This involved gluing a square of metal on the inside of the hole on the door, and filling the outside of the hole flush with the doors surface. This bodywork is visible, and unacceptable.
    Description: Primer is clearly visible as not enough base coats were sprayed to cover it.
    Description: Paint was sprayed directly over existing rock chips on the mirror. Chips should have been sanded out or filled.
    Location: Both sides of the vehicle, where the side moldings were.
    Description: I had the side moldings on the car removed, then the recessed areas on the panels they sat on filled/shaved flush. The bodywork done to these areas shows, and is unacceptable.
    Description: Inside upper lip of all fenders did not receive paint, only overspray
    Description: Area on the top of this panel, near the right license plate light never received paint. It was covered with masking tape.
    Description: Area was dented, it was not repaired to what I consider acceptable. Panel still wavy and uneven.
    Description: Area above the top most character line did not receive enough base coat. Primer is visable in several areas from the rear of the door, to the back of the rear side window.
    Location: Drivers side rear quarter panel, tail lamp area.
    Description: Area was built up with too much plastic filler. It sticks out way too far, and the tail light does not fit properly. Compare against the passenger side that is proper and then look at the driver side that is not proper.
    Description: Lower character line had left over filler on it that was not removed. The character line is as a result; sharp on the end towards the front of the car, and round near the rear (it should be rounded).
    Description: Mar in the finish, looks to be in the basecoat. Could be a “fisheye” or a place that was overlooked in sanding. I do not know. In-between the 2 character lines, and about 5in back of the door jam.
    Description: Upper character line was “burned through” during buffing. Area where paint was removed was masked off, and repainted. Masking lines are still clearly visible.
    Description: Lower front edge, paint was “burned through” during buffing. Area was never repainted.
    Description: Front middle edge was “burned through” during buffing. Area was never repainted.
    Description: Primer is clearly visible as not enough base coats were sprayed to cover it. No longer a issue, as the side skirts completely cover this area.
    Description: Run in the clear coat, just below lower character line.
    Description: Red paint (the doors original color) and primer is still clearly visible. Not enough primer was sprayed to cover the red paint, nor were there enough base coats to cover the red paint or primer.
    Description: Run in the clear coat, just below the lower character line.
    Description: Primer is visible and paint is “dry” not enough base coats were sprayed to cover the primer, and not enough clear coat was sprayed to cover the base coats.
    Description: Around latch area primer is visible, not enough base coats were sprayed to cover the primer.
    Description: The doors original color (light silver) is visible as the paint lifted off with the masking tape.
    Description: Overspray on the insides of all 4 wheel wells, and all over most of the suspension. Poor masking work. No longer such a concern as the ENTIRE suspension was removed, thrown away, and swapped for a entire suspension from a parts car.
    Description: Panel was wet sanded, to prepare it to be buffed. Was never buffed. Panel is dull and appears to be sanded.
    Description: Primer was visible to a horrid extend, and existing rock chips were painted directly over. Chips should have been sanded out or filled prior to painting panel. This panel doesn’t matter any more, as I replaced it with the updated style.
    https://mtechniqueabs.com/
  • bimmerphile
    • 3495
    Glad to hear that it might work out for you Jordan. Good Luck.
    :up:
    • Spaz
      Crazy Canuck
      • 2276
      damn jordan you got yourself on nice list.
      hopefully everything will be repaired correctly...knowning you it will be sooner or later, hopefully sooner so i can see you at the meet.
      Cam .W '91 325is
      Spaz's 1991 Alpine White???? S52 Build Thread...
      • ToplessE30
        • 4791
        That really is some kind of list you have put together. As I, and many others have already stated, I can't wait to see the finished product.
        Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
        • Erick
          Official R3V Drifter
          • 11169
          I just hope they dont come up with a whole new list of 25 NEW mistakes on the paint.
          ..::Support FullOpp::..
          FullOpp Stickers for sale!
          Feedback Thread
          • BrianF 88iS
            • 669
            I wil just wait til the list of paint problems comes out on movie
            Cant wait til the final product is show. How they do good.
            • Clay'87IS
              • 324
              Holy shit, thats a ton! Best of luck!
              -Jetta GLi
              • randomtask37
                • 3154
                thats quite a list. you dont miss anything do ya.
                98 M3/4/5
                • Jordan
                  • 12913
                  I do have 3yrs of professional auto detailing experience...
                  • Wes325
                    • 563
                    and it sounds like you are some kind of perfectionist. haha. Not a bad thing.
                    ________
                    mexicocity hotel
                    - 318is 4 life
                    • m42technic
                      • 1056
                      Do you mind me asking how much you paid for the original paint job?
                      The main thing that comes to mind is "you get what you pay for."
                      James Peacock
                      WWFSMD?
                      • Jordan
                        • 12913
                        I paid $2,000.
                        I brought them a completely gutted shell of a car
                        They had very very very minimal labor to perform. Moreover, the entire time i stressed that if more money was needed then the original quote to do it right, that was NOT a problem. The manager insisted on staying true to his qoute.
                        • Spaz
                          Crazy Canuck
                          • 2276
                          I paid $2,000.
                          how much of the sanding/primer prep work did you do jordan???
                          or did you just do the shaving?
                          Cam .W '91 325is
                          • Jordan
                            • 12913
                            I did most of the prep work, but any bodyshop is going to redo it all anyways else they wont warrenty their work.
                            • Jand3rson
                              • 37587
                              Oh man, I hope all goes well and it is done in time for the Picnic!
