E30 with motorcycle engine
  • ToplessE30
    • 4791
    Just curious as to if anyone knows if this has been done before (I'm sure it has)? I think it would be pretty cool because these cars can get somewhat light. Not miata/mini light, but decent enough and its an e30 so it would be cooler anyway.
    Could be useless daily or whatever, but just as a project car I think it could be pretty sweet if done correctly.
    Also, which would be more efficient? Front engine, or mid-rear? With the front you already have a firewall and subframe, so the rear would require a lot of work if you wanted to tie into the diff.
    I don't know, I've got a lot of projects on my mind, but I just want to get some opinions.
    Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
  • Firestorm
    • 795
    Not light enough.
    You'd want something 500-700kg for a bike motor.
    Lsx/t56 Swap progress |----------| .0000000005% - Well below poverty line.
    Getting purists panties in a knot since 2007. ;)
    E30 count = 6! :shock:
    • dredgfan
      • Aug 2007
      • 2636
      motorcycle engine
      if you do a swap it would probably be a good idea to think about torque. a suzuki gsxr1000 has 160hp but only 75ft-lbs of torque while the kawi zx14 is big cc's giving it a lot more torque with 115ft-lbs and a little more hp.So choose a big bike like a hayabusa or zx14 those are the two most powerful bikes out pretty much.that would be sick sounding with a yoshi pipe sticking out the back
      and check out the smart diablo on youtube
      • euroshark
        • Apr 2006
        • 3491
        Wouldn't be worth the time / money / engineering... Just not enough torque in those small motors. There is a reason the M3 got 6 cylinders after it had 4, and why it's getting 8 now after having 6, there is no replacement for displacement. Even turbos don't quite do the trick on really small motors... I can't imagine how shitty the driveability would be on a turbo 1000cc motorcycle engine in an E30, especially if it was pumping enough boost to make a good amount of torque.
        • TopOfTheLine89
          • Jun 2007
          • 919
          Just buy a honda,lol. 165 hp, not torque, nice and slow.
          97 tacoma 5 spd 4 cylinder
          2001 330ci 5 speed
          83 733i 5 speed, (FS)
          • dj2xrated
            • May 2007
            • 540
            idiot idea...
            Operation S/C E39M5.:woowoo:
            • Charlie
              kid tested, administrator approved
              • 6686
              It's been done, there's a couple of guys on the old BEN board with Busa-powered gutted e30s.
              -Charlie
              Swing wild, brake later, don't apologize.
              '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
              FYYFF
              • AndrewBird
                The Mad Scientist
                • 11896
                Just get the engine out of a Triumph Rocket III. 2300cc 140HP 147lb.ft. engine. Would be an upgrade from a 318i or 325e. LOL
                • e304me
                  • Feb 2006
                  • 1374
                  -Charlie
                  omg link?
                  • ColdAccord
                    • 5926
                    make a gixxercart
                    or buy an ariel atom
                    Originally posted by blunt
                    • Tavern Gnome
                      • 2137
                      How about a turbo busa engine in a RWD Rabbit?????
                      __________________
                      1987 Toyota Landcruiser V8
                      • Ben Carufel
                        • Jun 2004
                        • 5248
                        How about a Hartley V8? It's two Hayabusa engines siamesed.
                        400HP @ 10,000RPM on stock cams.
                        245lbs Tq @ 7500RPM.
                        Weighs 200lbs.
                        New 2.8 liter flat plane V8 sets new standards for compactness and power.
                        • Farbin Kaiber
                          Lil' Puppet
                          • 29502
                          Weighs 200lbs.
                          http://www.h1v8.com/
                          mommy...
                          • E30Idea
                            • Mar 2007
                            • 2196
                            ^^ Fucking sick
                            ** Lot's of M20 turbo parts for sale.**
                            Turn key track car.
                            http://www.r3vlimited.com/board/showthread.php?t=222066
                            • Tavern Gnome
                              • 2137
                              Weighs 200lbs.
                              wow!!!!!! Thanks for filling the spank bank
                              __________________
