What wheels should I get for the widebody
    Well its almost time to get some wheels on the widebody. I am looking at a 17x8.5-9 in the front and 17x10-12 in the rear. I dont have a ton of money to spend on wheels so something like HRE's are out of the question. I have been looking at Volk te-37's, SSR Competitions, and all sorts of Advan's. If anyone one has any other recommendations I would appreciate it. I am going to be running a 5x114.3 lug pattern with a 3ish offset in the front and a 15ish offset in the rear.
    Follow me @baysidefabrication on Instagram
    what 5 lug setup are you usuing to get a5x114.3 lug pattern?
      I am going custom. I talked to a local machine shop, and they can drill a 5x114.3 into the stock hubs and then tap to allow some studs to be put in. I know that if it is at all off it would vibrate BUT, the wheels are going to be hubcentric so if it was off just a little it wouldent matter you see. This is not completely definate yet. I am going to get one hub setup and a wheel and make sure everything goes smooth before I spend all this money on wheels.
        HRE or iForged all the way!
          HREs are soft. Ask Niel
            Fikse.
            A bit much, but can be made in any size to your tastes. Cheaper than HRE's.
            Or the ultimate BBS RS wheel. Nico custom makes them, but they do run high.
            Reminiscing...
              What about MKs ?
                Hummm....the hub on the e30 is really small, much much smaller than any 5 lug hub I have ever seen. Just for kickes I tried putting one of my e34 m5 wheels on the 4 lug hub of the e30...no way in the world you could ever redrill that and have it work, the brakes didn't even clear the hub of the wheel, not to mention the hole in the center of the wheel was way bigger than the hubcentring ring on the e30 hub. So I guess I'm saying I wouldn't expect just any 5xs114.3 wheel to bolt up to that without lots of reasearch or trying it first. Good luck. I'm looking forward to seeing the widebody done.
                  BBS Le Mans!!!
                  Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
                    Originally posted by diegom6
                    BBS Le Mans!!!
                      I'll Second that. Even redrilling a E34/36 hub is dodgy, if you take a look at the casting it is built up where the holes are to give more threads to use.
                      Easy way to do it would be, 5 Lug conversion using E36 parts, then run E34 offset wheels, piece of cake.
                      You will need to mod the body inside the front wheel well, or you will have serious body rubbing issues.
                      All good fun though.
                      292rwhp E30 :D
                        Interesting, I still have not pulled a hub off and checked the exact specs, this is all just what I thought might be a possible alternative to the e36 swap.
                          18in Simmons OM.
                          sigpicM42 Brigade ... Throwing craze in the 318
                            Originally posted by Streetspec_iS
                            18in Simmons OM.
                            -alex
                            i take pictures.
                              BBS Le Mans!!!
                              Originally posted by Gruelius
