What is required for E30 S38 swap?
  • ILoveMPower
    • 607
    Besides the donor engine and tranny, can you use many M30 swap pieces? Thanks for any insight
    - Jeremy
    '90 535iM ~200k
    '91 M5 ~152k
    1990 Islandgrun 535iM Sedan
    Euro lights + trim | Eibach/Bilstein | BBS RC090 17x8 | EAT Chip | Port + Polish | IE 284 Cam | Built valvetrain
  • Jean
    • 18228
    • ILoveMPower
      • 607
      Uhh, yeah...
      I mean mechanically, thanks for your wise insight.
      • Jean
        • 18228
        What M30 pieces do you have in mind ? (Other than possibly mounts, exhaust and tranny)
        • NC325iC
          • Mar 2004
          • 6565
          a shit load of dollaz
          • ILoveMPower
            • 607
            Thats exactly what I'm asking, how much of the shit can I buy and what needs to be fabbed?
            Never actually driven an e30, trying to make some plans for a "supercar"
            • Raxe
              • 5346
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                x2 on the above shots.
                • SpunkyE30nOk
                  • Jun 2006
                  • 228
                  you won't be able to use many m30 pieces..about the only thing the m30/s38 share is the block/oil pan/pump. you will need to use a later style oil pan/pump e32/34...the exhaust, and everything is different on the s38. you'll need the m5 ecu aswell the m30 won't work for it
                  • george graves
                    • 19993
                    What we are trying to say is "Don't worry, you will NEVER do it..."
                    You asked what other m30 parts do you use? Ummm - Like what spark plugs? It's a motor, you'll need that and, ummm yea the motor, motor mounts, and a tranny, drive shaft...oh and the motor. That is an easy 5k for a 150k+ motor, I would guess +3k for a rebuild on it in the next 20-30k.
                    If you need to rock your socks off thinking about it, go to e30.de and search around. You'll find plenty of e30/s38 porn.
                    BTW - the motor is a lot taller than a m30 (go figure), you have to space the sub frame by 20mm-30mm to clear the hood.
                    Sorry to be harsh, but there is a 99.99% chance you will never do it....
                    Originally posted by Matt-B
                    • LINUS
                      • 2422
                      Listen to all the above guys - once you are done you still have a VERY VERY expensive motor to keep healthy. There's a good reason we all get M/S50/2 motors & do those. A OBD1 M52 swap is half the cost of a S38, or really close. Plus if a M52 goes bad, you don't need a 2nd mortgage on your house to fix it.
                      You think we are all a bunch of smartasses posting pics of money, but really that's what it comes down to.
                      It's not how you handle the good times, but the faith you keep in the bad that defines you.
                      • DarkWing6
                        • Apr 2004
                        • 7144
                        I was going to say Vlad's bankroll, but the above pics took care of it. :D
                        • ILoveMPower
                          • 607
                          Guys, I own an s38 car as well as an m30 car, and I know the motors very well... I am refering to mounts quite obviously.
                          Now I remember why I stopped visiting this site, it's full of fucking haters rather than enthusiasts. If I wasn't interested in spending money, do you honestly think I would consider this swap?
                          If I wanted a fucking m50/2 car or a shitty underpowered us-spec S50/2 I would buy a shitty E36.
                          </end rage>
                          • Farbin Kaiber
                            Lil' Puppet
                            • 29502
                            </end rage>
                            I suggest you return to the whole "stopped visiting" thing if you don't like what the majority has to say. Maybe try an s38 site. If you have one, there must be resources you use for info, Here doesn't seem to be one. Thanks for the underlined dis. What do you expect people to respond to with comments like that?
                            BTW, I love M Power as well.
                            • shiftbmw
                              • Oct 2005
                              • 2012
                              Lots of cutting!
                              "The best argument against democracy is a five-minute conversation with the average voter." - Winston Churchill
