Mechanical Aptitude Test
  • NC325iC
    • Mar 2004
    • 6565
    86&#37; < Junior in mechanical engineering
    wtf how is this wrong
    air enters a NA ICE ____
    from suction due to the piston going down
    also where is option
    e) kg is not a measure of force
    • GarrettM
      • Jun 2007
      • 674
      Originally posted by NC325iC
      86% < Junior in mechanical engineering
      The correct answer to that is from atmospheric pressure. There is an absense of air inside the piston chamber there for the higher pressure pushes air into the chamber. That one threw me off too.
      • NC325iC
        • Mar 2004
        • 6565
        bastards thats like the same damn principle, the piston going down creates a vacuum and blah blah blah its just wording those dicks
        • PaintPro21
          • 660
          76&#37;
          although on some of the pics like the one with the cans that poor faster, I didn't inlarge the image to notice that one had a hole in it. made the same kind of mistake on some other ones.
          ApexRaceParts.com - Facebook - Twitter
          • whowhatwhere
            • Aug 2007
            • 259
            Not really. What would happen if an internal combustion engine was in outer space?
            In a forced induction engine, the piston doesnt suck any air in. It is forced by a simulated higher-than-atmospheric pressure. A N/A engine runs at 14.7 psi of "boost" (at sea level). "boosting" an engine means going over 14.7 psi.
            I got an 84&#37;
            Edit: That was a bad example. A normal N/A engine runs under 14.7 psi of boost. It comes from the pressure of the atmosphere. (assuming you are at sea-level). The air is forced in. not by a vaccum.
            • AlarmedBread
              • Sep 2006
              • 1510
              96. Fans and pipes pwnt me :(
              • ldsbeaker
                • Aug 2004
                • 3098
                78% I suck.
                Slicktop City!
                • jflip2002
                  • Sep 2006
                  • 4377
                  Im going to place near the bottom here, guaranteed....
                  Originally posted by blunt
                  • jflip2002
                    • Sep 2006
                    • 4377
                    70&#37; Ouch.
                    • Victell
                      • 1083
                      86&#37;. Id like to thank Lego for my passing score.
                      • whiltebeitel
                        • Apr 2007
                        • 2098
                        I got fan pwned, and i effed the electricalt parts, fuses and battries in series... this is what happens when you spend too much time with mathmatical derivation and not concepts. meh, 82&#37;
                        '89 325i track sloot
                        '01 530i daily
                        -Enginerd
                        • ivo316
                          • Oct 2006
                          • 1222
                          410 points = 82% :p
                          • Justin B
                            Sikky Nar Nar
                            • Mar 2005
                            • 4273
                            90&#37;. There were a few confusing ones for sure. Good enough for me. I just wish they showed which ones I got wrong and what the right answer was.
                            • ivo316
                              • Oct 2006
                              • 1222
                              Indeed, but since the pressure inside the cylinder is the same as the one in the atmosphere because the cylinder is not sealed, there is no forced induction, it would be if you had a vaccum in an airtight cylinder and you opened the intake valve to let atmospheric pressure go in, but in a normal engine the air is actually sucked in by the displacement of the piston... ;)
                              • kellie
                                • 702
                                Ugh, that test is too long. I only answered the first 5 questions, then got bored. I don't like taking tests unless I have to.
