What to replace while engine and tranny are out
  • timothy100
    • 125
    I have a 325i engine and 5 speed transmission sitting in my garage that I bought to do the e to i engine swap and automatic to 5 speed swap. What wear and tear parts do you guys think I should replace while the engine and transmission are out? I think the engine and transmission has about 160k miles on it. I don't want to have to take the transmission out in 6 months because I find out something needs to be replaced...
    Thanks
  • rwh11385
    lance_entities
    • 18403
    When my head was swapped, all the heater hoses were replaced. Those things are a bitch to get to my buddy said and they were dried, cracked. Better to get all them refreshed than to have to replace them one at a time. Belts, spark plugs, filters, etc.
    • Jordan
      • 12913
      Rear main seal (engine), oil pan gasket, rear main seal (tranny) shift selector seal. Fill tranny with Redline etc.
      https://mtechniqueabs.com/
      • M-technik-3
        • 18946
        Blower motor.
        • AndrewBird
          The Mad Scientist
          • 11898
          Clutch if needed. Pian in the ass to have to pull the motor just to replace it.
          Andrew
          • Super Eta
            • 1884
            Andrew
            cant you just drop the tranny down out of the car and put it on a bench and replace it (clutch) that way instead of taking out the whole engine?
            • 318daily
              • 507
              motor mounts, tranny mounts, center support bearing, guibo. May as well do all rubber hoses too just for peace of mind.
                • 34839
                Andrew
                why would he want to do that? the motorand tranny are already out of the car, it'd be much easier to do that now.
                • e30evolution
                  West Werks
                  • 1888
                  clutch on this car is like a 3 hour job... almost as easy as an A2 VW....
                  heater hoses, def, and replace the control arms/ball joints, inspect the tie rods,ends and check the rack boots for damage or weathering
                  http://www.westwerksauto.com
                  • Super Eta
                    • 1884
                    Andrew
                    no i was referring to his Nirto's comment about having to pull the engine out in order to replace the clutch
