Defroster question
    Defroster question
    Is A/C required for the windshield defroster (or de-fogger) to work, or is all that's needed a working blower fan ?
    I removed the whole a/c, heater system from my e30 a while back and now thinking about installing half of it back just so that I can drive safely when it rains. I don't care for heat or a/c.
    So, to save me the trouble would installing just the blower fan work or do I also need the heater ?
    i don't have an ac compressor currently and it works. HOWEVER it works alot quicker with ac. Sometimes I crack the pass window to get it to clear up quicker.
    Yours truly,
    Rich
    you kids get off my lawn.....
      a/c is not required for the windshield defroster to work it just helps it work because it removes moisture and heat from the air. i believe you could get away with just the blower, but id put the heater in too. especially if you are in a climate that temperature fluctuates. that way you can apply heat when needed to help defrost your window.
      e30s r kool
        You don't care for heat or A/C? You're crazy man.
        But then again, it's about 20 F outside, and it's probably a bit warmer where you're at.
          And do you not care for a cluster too?
            Dash with cluster, glove box, stereo etc is in place :) There are just far too many things I'll need to source to get the heat back on, let alone A/C. I tossed the whole assembly out.
              ^^^ Dieting you car will only work so much Jean. You need more powah!
              Jon
              Rides...
              1991 325i - sold :(
              2004 2WD Frontier King Cab
              RIP #17 Jules Bianchi
                Jon
                Working on that :) Too bad $ doesn't grow on trees :(
