So I weighed the 318 today
  • arnoldgtr
    • Mar 2004
    • 153
    Actually, the E30 318i M10 lost weight, compared to the E21 320i.
    According to the 3- Series Enthusiast's Companion:
    E21 320i...2500
    E30 318i 1984...2360
    E30 318is...2602
    Also, converting to the plastic bumpers doesn't save much weight at all. I figured the weights from the ETK, and the total weight saving was 4.4 pounds:
    Front aluminum = 23.73 pounds
    Front plastic = 20.37 pounds
    Rear aluminum = 26.55 pounds
    Rear plastic = 25.51 pounds
    John
    88 ///M3 Cinnabar
    84 318i Black
    • Stu Mc
      • 4083
      M10 weighs about 335, M42 is around 310.
      • matt325is
        • 409
        I weighed mine a couple months ago. 2760
        It had 1/2 tank gas, turbo/piping (add weight), no a/c, no pwr steering, 17" kopi's, stock interior except I had the racing seats, amp in back, all tire change equip.
        matt
        • Digitalwave
          is a poseur
          • 6299
          Bill, I would like to experience your car.
          RISING EDGE
          • arnoldgtr
            • Mar 2004
            • 153
            M10 weighs 335? Is it full of lead? Sorry, I don't believe that figure.
            The 318i M10 is 242 lbs lighter than the 318is M42, partly because of the engine. Drive one and tell me it is heavier in the front than a 318is.
            ETK shows 90.5 kg for a reman M10 short engine. Add manifolds and the number is 100.5 kg, or 221 lbs.
            A reman M42 short engine weighs 110 kg. Add manifolds for a total of 119.7 kg, or 267 lbs.
            John
            88 ///M3 Cinnabar
            84 318i Black
            • bimmerphile
              • 3495
              M10 - 180.78lbs (82kg)
              M42 - 220.46lbs (100kg)
              Stop smokin that crack stu it's makin you retawded.
              EDIT: Interesting: M54 - 277.78lbs (126kg)
              • LowR3V'in
                • 4209
                arnoldgtr:
                Can you look up how much the bumpers shocks wieght, please?
                Thank you.
                • Jand3rson
                  • 37587
                  Seriously, will you GET RID of that god damn sig? It's the most annoying thing n the planet, I get a headache just seeing it out of the corner of my eye.
                  • LowR3V'in
                    • 4209
                    Na, I like it..
                    Sorry, if it's anoying to you.
                    • arnoldgtr
                      • Mar 2004
                      • 153
                      Bumper Shock weights
                      It would help if you specified which shock, but here goes:
                      Aluminum front....2.73 lbs
                      Aluminum rear....3.17 lbs
                      Plastic front....2.15 lbs left, 2.43 lbs right (what?)
                      Plastic rear....1.98 lbs
                      That is the bare shocks, no bolts, brackets, etc.
                      HTH,
                      John
                      88 ///M3 Cinnabar
                      84 318i Black
                      • Bill 84 318i
                        • 1600
                        Re: Bumper Shock weights
                        My guess is the difference is in the provision for the tow hook.
                        • AdamF 88iS
                          • 2051
                          Originally posted by LowR3V'in
                          Na, I like it..
                          Adam Fogg- '88 M3
                          Common sense- It's the new 'gifted'
                          • Bill 84 318i
                            • 1600
                            Na, I like it..
                            Oh snap. I say to pick a find a retarded thread and post that, and look what happens.
                            So it's like that?
                            • kencopperwheat
                              King of Kegstands
                              • 14396
                              ...that sig makes no fucking sense...
                              Originally posted by Gruelius
                              • arnoldgtr
                                • Mar 2004
                                • 153
                                Good call, Bill.
                                Duh...I just wasn't thinking.
                                After I spent two weeks looking for a reasonably priced screw-in towing eye for my 318i plastic bumper conversion.
                                I ended up buying an E36 tool kit, on the off chance that the towing eye would work. I already knew the ETK showed a different part number. Well, FYI, it works. The threads are the same...the only difference is the plating and the length. The E36 towing eye is slightly longer, and it has silver colored plating, instead of the yellowish plating of the E30 eye.
                                John
                                88 ///M3 Cinnabar
                                84 318i Black
