all eta owners with JC chips...
  • greateratlanta
    • May 2004
    • 50
    Originally posted by RedBaron86325
    Add a 3.46lsd and a set of 325i inner valve springs and you'll hang right with the i guys.
    Maybe I am just not thinking this one through, but how does adding i valve springs effect the performance of the engine? It's not like you are changing the valve lift....only a hot cam can do that. Seems like you are limited by the short lobes on the stock cam.
    • Digitalwave
      is a poseur
      • 6300
      e's only have single valve springs, so adding the i inner valve springs gives you dual valve springs, and greatly reduces valve float/lets you spin higher RPM's.
      RISING EDGE
      • greateratlanta
        • May 2004
        • 50
        I see
        Thanks
        Edit: Does adding the inner spring change your vavle settings or do you keep the stock limits when adjusting valves?
        • PJG
          • Mar 2004
          • 5
          Okay, here's a quick, dumb question. Anyone know why the Jim C chip for the 318 costs $50 more?
          • BavarianBimmer
            • 951
            I tought an M10b18 can't be chipped (correct me if I'm wrong) 'cause it has an L-jet injection system
            Only Motronics can be chipped
            1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
            1997 E36 328iT
            1990 E30 325iT 24v SOLD
            1989 E30 325i 2.7i M-Technic II SOLD
            • PJG
              • Mar 2004
              • 5
              Well according to Turner's site, they do make one for the 90-91 318's. Too bad at the present moment that site is inopperable.
              I guess it would have helped for me to say what type of car I have.
              91 318i 4door, Alpine White II
              • BavarianBimmer
                • 951
                an 1991 ? An M40 and those can be chipped ;)
                M10's were produced till 1987 approx.
                1997 E36 328iT
                • BavarianBimmer
                  • 951
                  M10 engine bay
                  M40 engine bay
                  1997 E36 328iT
                  • rede30
                    • 4697
                    i know with cips they utilize the 91 oct but if someone had a chip and didnt have the money for the higher gass could they just throw 87 in and loose some power but not hurt anything. thanks
                    Dustin
                    • PJG
                      • Mar 2004
                      • 5
                      Boy, that sure is one Dirty Engine Bay ;) j/k
                      • BeirBrennerE30
                        • 2740
                        Dustin
                        not exactily...
                        e30sport.net
                        '06 M3 Competition - 6-speed
                        '97 Range Rover Vitesse
                        • rede30
                          • 4697
                          so would it be a bad thing to not put 91 in your tank with a chip in
                          • BeirBrennerE30
                            • 2740
                            you would probably get a bit of knock if you put lower then the recomended grade fuel...
                            e30sport.net
                            • greateratlanta
                              • May 2004
                              • 50
                              Quick fix:
                              Hang on to your original chip. Whenever you can't afford the good stuff just replace the performance chip with the original. Problem solved.
                              -Clayton
                              • Psychomofo
                                • 95
                                quick question about that picture of the M10. is that vaccuum hose that goes to the distributor coming directly off the intake manifold? what is the correct routing for the vaccuum hoses for the timing advance? i just want to make sure i've got it right. i'm pretty sure that i do, but just to be 100% ya know?
                                p.s. sorry to change the subject, but back on subject. is there any way to do any kind of electrical work with the AFM or coolant temp. sensor so that you can get more fuel to the engine? well, to put it simply. is it possible to get the same results as a chip from doing something like that, or would it really be just incredibly complicated?
