drivers side oil leak
  • roundel
    • Aug 2007
    • 111
    hey guys, i'm having some trouble figureing out what the problem is. i know where the oil is coming from but i cant figure out what it is or how to get to it. it is the pipe under the intake manifold. has anybody had this problem? it had been leaking,but now it is just gushing out.
    i figure it ;is the oil return pipe. does anybody have any experiance with this
    Getting there
  • Jordan
    • 12916
    there is an oring at the top and bottom.
    https://mtechniqueabs.com/
    • TwoJ's
      • Oct 2005
      • 4908
      The one that goes from the intake manifold down to the pan? That's a crank case breather, and it shouldn't be gushing out oil. Did you overfill the oil? There are o-rings, but I wouldn't think there should be much oil in the tube.
      • Jordan
        • 12916
        Um.. its a breather tube, but oil also drains from the head down to the sump through it. I suspect that oil is his problem.
        • roundel
          • Aug 2007
          • 111
          not gushing like a hose but leaking in fact i didn't know it was leaking till my oil light went on, parked in a lot and saw a puddle of oil under the car
          Getting there
            • 34839
            if the o-rings are shot or missing, it creates a vacuum leak which will suck oil into the intake. I don't know how or why, but that's what happens.
            • roundel
              • Aug 2007
              • 111
              i just cant find it on alldata or in the haynes manual and i dont want to start taking shit apart without a plan.
              Getting there
              • AlarmedBread
                • Sep 2006
                • 1510
                http://www.realoem.com/bmw/showparts...19&hg=11&fg=10
                • roundel
                  • Aug 2007
                  • 111
                  alright im gonna get to it thanks everybody
                  Getting there
                  • TwoJ's
                    • Oct 2005
                    • 4908
                    Okay, I stand corrected and realize that oil drains down it, but it should not be under enough pressure to spew out. Like stated, if the O-rings were bad you would think that vacuum would suck air in, not let the oil out. Crank case should not be under pressure, right?
                    And have fun with that thing, it's kind of a bitch the first time you do it. I found it helpful to compress the spring at the top of it and zip tie it to keep it compressed. Then get it in and cut the zip tie to release the spring.
                    • mudflaps
                      • 808
                      i believe at r3v we call it the spring loaded tube of death.
                      im sorry for your luck.
                        • 34839
                        it's not that big of a deal
                        and the spring is on the bottom, not the top :p
                        • TwoJ's
                          • Oct 2005
                          • 4908
                          Yeah, it's been a couple years since I've done it. My memory is fading at a young age. It's not too bad if you've done it once, but it can take a minute to figure out.
                          • roundel
                            • Aug 2007
                            • 111
                            you know i typed in "tube of death" and i got more search responces than when i typed in oil return pipe. I see that most people were taking off their intake manifold and had a problem with the tube of death. So the intake manifold has to be removed first. I just wanted to check if there was any kind of "easy button" to take the tube out.
                            Getting there
                            • Jordan
                              • 12916
                              You can change the top oring (the one I'm sure is leaking) without removing the intake manifold.
                              The bottom requires you remove the intake manifold.
