I just pissed someone off, need to vent...
  • xLibelle
    • Aug 2004
    • 2673
    So the windshiled installer just left my house with a slight attitude. I surely can say i helped but it was coming to him.
    I didnt care for his attitude or his work and he appeared to know nothing about installing a bmw window.
    Is there a wrong way to install the window? He didnt want to use any glue material, stating the gasket does the job. Then after i convinced him i wouldnt accept it w/o the glue stuff (he had some in the truck), he did a horrid job putting in the gasket (w/o glue) and had to take it back out to get it right, which is when i relieved him of his services.
    Does this 'glue' go before and after the gasket or does it not matter?
    I'm obviously going with another company this time though.
  • ak96ss
    • Nov 2005
    • 461
    AFAIK, only the M3 used the adhesive. Normal E30s do not, they only have the gasket, which is infinitely preferable when you have to replace it again.
    The installer I had do my windshield a few years ago used the adhesive - it took over 2 hours to remove all that crap, and I literally broke the windshield trying to remove it.
    Your installer was right.
    John in MD - 1991 318is
    190k miles and still rolling!
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      ouch. tail between legs moment. call and send him a bottle of wine.
      • M42Technik
        • 9781
        John is right on all counts, sorry dude.
        Reminiscing...
        • Dave
          E30 RAT
          • 11675
          Oops, you made a boo-boo.
          I have removed/replaced several e30 windshields. You dont use any glue - the gasket indeed does the job.
          Helps to have the lock strip install tool or else you will be cursing with a soapy water covered spatula trying to get that bugger in.
          Current Cars
          2014 M235i
          2009 R56 Cooper S
          1998 M3
          1997 M3
          • atomic
            • Jun 2007
            • 5691
            Oh damn no wonder the windshield installer was pissed ..... He was right !
            Only the e30 M3 had glue in windwhields all other are held in place by the lock strip in the gasket
            Installer 1
            xLibelle 0
            • Funkmasta
              • May 2004
              • 7185
              I would call with an apology... Depending on his character, you may have a comprehensive claim tomorrow morning.
              Maybe a gift certificate to Applebees?
              Joe Funk -- Portland Oregon
              That Guy.
              03 X5. 3 liter obviously.
              • mrsleeve
                • Mar 2005
                • 16390
                No glue was used when they put mine but they did put a very small bead of silicone in under the gasket.
                Originally posted by Fusion
                William Pitt-
                • FredK
                  • 14763
                  ooh. On a related note, if the window isn't glued, how do I remove it from the gasket? I already removed the lockstrip.
                  • erik325i
                    • Jan 2005
                    • 3567
                    hahaha
                    • e30 Luv
                      • Dec 2006
                      • 395
                      Anyone know where to get this tool or what it looks like? I traded out both front and rear windshields and had a hell of a time putting that lock strip back in. I never did get the rear corner pieces back in.
                      • erik325i
                        • Jan 2005
                        • 3567
                        I bought mine from Bav Auto if I recall correctly. It didn't help much. I found it easier to just use soapy watter and a flathead screwdriver.
                        -Erik
                        • Ben Carufel
                          • Jun 2004
                          • 5248
                          You already removed the lockstrip? Then it should just push out from the gasket. Carefully and slowly push from the inside and you should be able to pop it free from the gasket.
                          • erik325i
                            • Jan 2005
                            • 3567
                            Once the lockstrip is removed, just press up from the inside and press the window out of the car. It will either push the windshield out of the gasket, or will take the gasket with the windshield. Either way, it's pretty easy.
                            -Erik
                            • FredK
                              • 14763
                              thanks for the tip erik! hopefully I don't drop my windshield onto the ground while pushing on it!
