My T3 vs. my T4!! Question and Pics
  • diegom6
    • 4447
    I got this fully T4 and I'm swapping it right now.
    The back is A/R 100, the turbine (or vaines size) arent't messure yet, but tomorrow will do that and will psot here making the marks in each turbo to diffrence both in sizes.
    T3/T4 in the Left and the New One , Fully T4 on the right!
    The T3/T4 at simple "eye" or "look" the blades or turbine is a bit smaller than the fully T4 even when both has T4 front Compressors with .60 A/R, tomorrow I will messure it and post then here.
    T3/T4
    T4
    A side Note, could someone tell what type of front compressor I have in the New T4? I'm not sure if that is "H" or "M" model/code housing type, cuz the older is "B" trim.....
    anyways, what are the advantages or downs?
    Thanks
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
  • Rob
    • 8166
    Sweet, when does it go in? Whenever that is, I'm giving you 2 months before you blow your motor again :P
    BEERTECH
    • diegom6
      • 4447
      lo. it won't happen, this time i will tune that crapp like it has to be...no more pinging and those problems....
      Now that I see both turbos, I'm seriously thinking in make a big Bi turbo setup!!! :twisted:
      • 808BMW
        • 2910
        So your turbine housing a/r is 100?
        With this new turbo you can tell it will spool up later just by the pics alone.
        Larger turbine housing:
        Produces more air to the engine per engine rpm
        Provides more horsepower potential but less low end torque
        Results in slower spool-up and increased turbo lag
        Do you have the full specs?
        • diegom6
          • 4447
          I know I know...lag will be my enemy now, i don't care...no, i don't ahve the specs on it, I got that Turbo for $102 Remanufactured for Volvo, all new I think.
          Like I said in my post will messure all the things to compare both...
          • DIEGO-E30
            • 48
            :stupid: te doy 3 semanas y soplas o pegas!!!!
            • 808BMW
              • 2910
              I think the last turbo is good enough.
              You have SMT6 now right? The only thing this bigger turbo lets you do is run more boost this time, but the main thing holding you back in the first place was tuning.
              The turbo I'm going to order has an exhaust housing a/r of .82, which should be good to run 18 lbs. of boost if I wanted too. I don't know how this thing will turn out :P
              • TCD
                • 438
                Diego,
                I hate to be the one to tell you that that turbo is a horrible choice! It's for a constant rpm diesel motor in some sort of equipment. Your tiny little 2.5L will never sppol that turbine with the huge a/r and likely "P" trim turbine. We wouldn't even use something that big on our 3.4Ls.
                Sorry,
                Todd
                TCD
                1985 euro 535i
                503rwhp/485rwtq
                • diegom6
                  • 4447
                  Originally posted by TCD
                  Diego,
                  Sorry,
                  Todd
                  "P" trim? what is that? what Trim I have, "M" or "H"? cannot see the difference...
                  a side note, skatanic(Alex) has a friend who dropped a T4 with .80 AR int he front a A/R 100 in the back on a eta stock and says that the eta move that huge turbo with out major problems.
                  • skat 325is
                    • 296
                    Diego post the pic i sent you, im too tired right now. :?
                    That 325e pulled a 19psi run before he bent 4 valves
                    • TCD
                      • 438
                      I don't know about Skat325is' friend but your motor will NOT push that turbine with a 1.00! You'll be lucky to see full boost at 4000rpm.
                      Todd
                      TCD
                      1985 euro 535i
                      503rwhp/485rwtq
                      • diegom6
                        • 4447
                        here is Alex, explain to us how that ETA handle that big ass turbo, how spool it
                        • CobraKai
                          • 1544
                          -alex
                          i take pictures.
                          • Jordan
                            • 12916
                            Holy crap, that is the WORST exhuast collector setup I've ever seen.
                            https://mtechniqueabs.com/
                            • wheelman
                              • Mar 2004
                              • 17
                              second that :o
