Got a Nice Turbonetics!!! Pics..!
  • diegom6
    • 4447
    Ok, since most people said me don't use the bigg T4, I ofund this turbonetics in a local speed turbo shopp and bought it, it is used but is in perfect condition.
    Some differences between this one and the old T3/T4 is tha tthe cold hosuing a bit larger, more important the wheel or compressor is larger and has 7 vanes instaed of 8 like th eolder with a diameter of 54mm inducer(front part) with a base diameter of 76mm.
    The rear is .63 instaed of .48 as the previous using the same wastegate(internal) , the rear wheel is about 53mm of diameter and as you can see tha vanes are way different than the T3 standar, a lot more strights wich means mnmore exit flow!!
    Also noticed that the wheel/shaft is a lot lighter than the T3 and the compressor vanes are lighter or thinner than the t3/t4 tough....
    You can comapre these photos here
    T3/T4
    vs
    Turbonetics
    T3/T4 rear, super restricted wheel/turbine on the LEFT!!!
    vs Turbonetics super free flow wheel!!
    Also machined the exit of the housing a bit for better exit flows..
    What are your toughts? :D
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
  • Kondour
    • 243
    Finger chopper for sure :twisted:
    • e30evolution
      West Werks
      • 1888
      i think the new one looks like a good choice... definetly better flowing design.... but you are saying that it is bigger?
      http://www.westwerksauto.com
      • diegom6
        • 4447
        yes, it's bigger, the rear tapped or what ever is called is the same as the previous T3/T4 as you can see in the last pic and before the last pic.
        But, the turbine ( hot wheel) is larger diameter, has different form/type vanes for better flow and is lighter, the A/R ont he hot isde is .63 wich is larger than my previous T3/T3 wich is .48A/R
        The front also is a bit larger, and the compressor is bigger than the previous T4.
        All this with a nice wirght reduction for fast spool!! :D
        • E30godz
          • 1524
          i need a .63 exhaust housing too 8(
          • diegom6
            • 4447
            what turbo/specs do you have?
            • E30godz
              • 1524
              T3 60 trim, .60 compressor housing and .48 exhaust housing with a stage 3 turbine wheel....i feel the .48 exhaust housing is a big restriction.
              i wouldnt mind upgrading to a t4 compressor wheel, whatever wheel that TCD is using as he has been having so much success
              • diegom6
                • 4447
                I had the same .48 in the back with a standar T3 turbine, I felt the car so restricted, that's why I'm upgrading with a bigger unit.
                Dunno what Trim is this one but it has 7 vanes instaed of 8 like the old one and thinner blades tough in result of a light weight compressor/turbine
                • E30godz
                  • 1524
                  think you can score me a .63 turbine housing that can be used with an internal wastegate?
                  • diegom6
                    • 4447
                    start to search in ebay...other than that only in turbo shopps where is most expensive
                    • diegom6
                      • 4447
                      by tomorrow will be finished the turbo install, will tok some pics, and I'm keeping all the pipes stock, also the poor IC yet, since I will wait for the new onw and then will dropp a 3" downpipe and bigger IC pipes...
