Oil Tube to block - parts sequence help needed
  • smcdermott326
    • Jan 2008
    • 84
    Can someone advise the exact order of placement/relationship for the Oil feed tube parts from the bottom of the intake to the block?
    The Real OEM diagram doesn't show the position of each piece:
    09O-RING211151714390
    10FLAT WASHER211151280937
    11COMPRESSION SPRING111151265346
    12PIPE111151280938
    Thanks,
    Steve
  • smcdermott326
    • Jan 2008
    • 84
    That's 2 flat washers and 2 o-rings
    • mudflaps
      • 808
      springloaded tube of death?
      just sell the car.
      • smcdermott326
        • Jan 2008
        • 84
        yes the tube of death. It's leaking enough that I want to redo it but I am not certain it is currently installed correctly since it has been uninstalled/reinstalled several times already.
        • TwoJ's
          • Oct 2005
          • 4908
          I have to go to class right now, or I'd look it up for you. Go to www.realoem.com and look for the diagram for the intake manifold. It may be on there. It's been a while since I've done mine, but I beleive the spring goes on the bottom. Definetly double check that though.
          Good luck, that's kind of a bitch to do.
            • 34839
            spring goes on the bottom, o-rings go on bottom and top. I don't remember any washers.
            • e30Matt
              • 5077
              Top just has an o-ring.
              Bottom goes spring, washer, o-ring from top to bottom.The washer is so the spring has something flat to press on the o-ring.
                • 34839
                that's right - it's been a while.
                • mudflaps
                  • 808
                  installing it is the easy part. its cramming the 25lbs of sand into the crank case hole thats the hard part, but the gains are incredible for this mod.
                  • smcdermott326
                    • Jan 2008
                    • 84
                    Thanks for the help.
                    Any idea why Realoem would show 2 flat washers if there is only 1 for the spring to rest against? Where does the other one go?
                    http://www.realoem.com/bmw/showparts..._0106&hg=11&fg
                    • Toms73NovaSS
                      • Oct 2007
                      • 246
                      I only see one washer. the lower one is the o-ring.
                      • smcdermott326
                        • Jan 2008
                        • 84
                        but the QTY is 2....just like the o-rings...you only see the bottom one but there is a top one as well that's not shown.
                        • Toms73NovaSS
                          • Oct 2007
                          • 246
                          got it! I don't know what it originally had. However a washer up top would provide a more perpendicular edge for the oring to sit on rather than the radius-ed (Sp!) surface of the tube flange....????
                          • ldsbeaker
                            • Aug 2004
                            • 3098
                            Pics?
                            That would really help the rest of us.
                            Slicktop City!
                            • smcdermott326
                              • Jan 2008
                              • 84
                              realoem HTML link is in above post to see the pics
